Fuel Pressure Regulator?
Old May 21, 2002 | 07:21 PM
96BLUMAX's Avatar
How does this work? I have looked at it and I was wondering how it increases pressure? Also how much of an effect with one have. Can it work in conjunction with an APexi SAFC? Can someone explain?
Old May 21, 2002 | 07:50 PM
MDubya
someone answer
I wish someone would answer you .
I need to know these things too.
Old May 21, 2002 | 08:17 PM
Aaron's Avatar
Langley AFB Sux
Try the ............SEARCH...... nm
Old May 21, 2002 | 08:36 PM
sx7r's Avatar
on an aftermarket fuel pressure regulator, inlet pressure is controlled via a diaphram and spring which restricts fuel flow exiting the fpr. a screw on the exterior of the fpr adjusts the tension in the spring/diaphram. the more the flow is restricted, the higher the pressure on the inlet side of the fpr.
an fpr can work in conjunction with an s-afc because the afc alters the signal from the MAF sensor to the ECU. it tricks the ECU into thinking there's more or less air flow than there actually is and the ECU compensates by altering injector pulse width accordingly.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
