FSTB, improvement or BS?
Read plenty of posts here the last few days on the subject, and I just don't get all the hype. How can a $75 tube of aluminum be as great an improvement in handling as some are saying? I'm sure there's some amount of flex in the towers during hard cornering, but that much to make a difference? Aren't other structural items (firewall) on the vehical already providing enough support between the towers? I'd like to hear from both sides...
Re: FSTB, improvement or BS?
I put on the new courtesy FSTB a month or two ago. And can honestly say it is the best $69 I have spent so far. I wasn't expecting to feel a difference, but did. Immediately. And it seems that if you have the car lowered, wide wheels/tires, etc that the benefit would be more significant. As you would be more inclined to push the car in situations you otherwise may not.
Not BS or else everyone on the board wouldn't have one.
Hmmmm ... bad example ... lots of people have Altezzas and think they look good.
But seriously ... it is beneficial whether you are lowered or not. It is just less noticable if you are lowered.
I put on one of those cheap FSB's found on Ebay for $20 and it really makes a big difference in mid and high speed cornering. Before - when pushed really hard into a corner sharp corner at 40-50ish MPH, I would end up with huge amounts of understeer all the way. Now - there is a bit of understeer right at the turn-in , but the car is much better balanced mid-corner and towards the exit and the confidence it gives is amazing. On a downhill cloverleaf I take a couple of times a week, after the FSB was installed - the Maxima is a lot more responsive to mid-corner throttle changes. When it starts pushing, getting off the gas has a better effect on the car. BTW/ I have a GXE with stock (steel) wheels running Michelin MXV4's - maybe this is why I feel such a big improvement.
My advise is get it. You won't regret it.
Also a question to others that have instaleld FSB's. Did anyone notice a slight increase in front suspension noise when going over bumps and such?
Did you go with the RSTB as well, or an RSB?
My car had the stock SE setup with FSTB and RSB for the 1st 100K miles. Those 2 things took my car to another level. Then I upgraded to H&Rs and Toks. The suspension got better for driving, a bit worse for comfort. And it also got better looking with the drop. I could have replaced the stock setup with stock again if only the ride height was not so high.
DW
DW
carid
09-09-2015 05:06 AM
