Altezza Housing
Old May 22, 2002 | 08:52 PM
97maximase5spd's Avatar
Altezza Housing
Hey, has anyone ever tried to take apart the altezza housing. I don't know i it would work the same as taking apart the stock housing. Any info. would be appreciated
Old May 22, 2002 | 10:45 PM
TintDaMax's Avatar
Re: Altezza Housing
AHHHHHHHHHHH! Search for gods sakes!
DPW
Old May 23, 2002 | 01:08 AM
Beleive me, I have. There's no info on what I'm looking for. I'd like to take the clear outer lens out, so I can modify the chrome part on the inside. I'd rather ask for people's advice then ruin the tailights myself
Old May 23, 2002 | 03:26 AM
elcid's Avatar
I would like to know this aswell
Old May 23, 2002 | 07:44 AM
gedck's Avatar
I took apart the inner tails by boling a large pot of water, dipping the corner that I wanted to start at in, waiting 30 secs or so. Remove from the water, and began to pry with a butter knife very gently. Keep doing this carefully with all 4 corners and it should come apart with no damage done to the housing.
I haven't tried this with the outer lights, but I would assume it would work just the same.
Also: DO NOT just put the lights in the boiling water and walk away. Keep a close eye on them, and do not let them touch the very bottom of the pot.
Worked for me
Greg
Old May 23, 2002 | 08:18 AM
CKNY's Avatar
My experience is that the inner lights are easy to take apart using a heat gun patience. The outer ones are near impossible to do without cracking. After ruining two pairs i said fug it. =)
Old May 23, 2002 | 05:27 PM
Ravq's Avatar
Found this using the search.
http://forums.maxima.org/showthread....paint+altezzas
Old May 23, 2002 | 05:30 PM
Ravq's Avatar
Also brief how2. (Although I don't recommend the process.)
http://hometown.aol.com/ravq/Altezza.html
Old May 23, 2002 | 05:52 PM
Gary95's Avatar
Re: Altezza Housing
Why do you want to do this? Are you thinking of painting inside it or doing some other kind of mod? These lights are fragile as hell. As other people have pointed out, many attempts have resulted in trashed housings. I strongly recommend against it.
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
