MAXIMA transmission bearings problems...easy to spot?
Old May 24, 2002 | 07:35 AM
meccanoble's Avatar
Sports Button FTW
doing conversion like most and when i go to pick up trans from junk yard, i want to make sure i won't have problems with bearings...i have warranty and all but i don't want to have it installed, THEN find out my trans is garbage...is there ANY way to find out if the trans will give you problems just by looking at it before you even install?
also, how much would fixing the bearings on a trans cost?
Old May 24, 2002 | 07:40 AM
njmaxseltd's Avatar
Tare it down, inspect it, replace any components which appear worn, put all new seals in it and consider yourself the owner of a rebuilt tranny!
Old May 24, 2002 | 07:49 AM
meccanoble's Avatar
Sports Button FTW
how much you think all of that is going to cost?
and if i'm going to do that, u think i should just buy a messed up tranny and have someone rebuild it for me?
Old May 24, 2002 | 10:26 AM
njmaxseltd's Avatar
Get a tranny and inspect it. There's no way to know what your actually getting unless you take a look inside. The seals aren't that expensive. If you open it up and everything looks good, then consider yourself lucky! Just put all new seals in it and install it. If you open it up and find metal flake, bearings that don't look so hot and chipped or worn syncros, then your in for a few bucks. But again, the tranny is already out of the car so your saving yourself that cost.
I say open it and inspect it. It's cheap insurance.
Old May 24, 2002 | 10:31 AM
sil SE's Avatar
tom where and what exactly are the synchros in my 5spd
Old May 24, 2002 | 10:55 AM
boosted95's Avatar
meccanoble
where in jersey are you gettin yer tranny from and how much?? im lookin for one too, wondering where? also are buyin just the tranny or the clutch and everything from that place??
Old May 24, 2002 | 12:46 PM
njmaxseltd's Avatar
I couldn't describe that to you. There sort of next to or set up against the gears themselves. All assembled on the main shaft. You'd really need a pic from the FSM to see them. There kind of smaller then the gears themselves with angled teeth. Unless your a transmssion guy or have taken apart a 5speed, your not going to know whats what in there.
I've done a 5 speed before, it was actually quite easy to rebuild. I didn't have to touch the main shaft of half (secondard) shaft, but have replaced all the bearings. You will need a press to get some of them in and out.
Old May 24, 2002 | 11:08 PM
meccanoble's Avatar
Sports Button FTW
Re: meccanoble
i'm getting my trans from this place near freehold new jersey...i put a deposit already...not the best price but it's better tha nnothing....i have no idea how to open the trans and all but my friend does...what are the possible problems that can occur? just the bearings? seal problems? can you tell me what i should look for to make sure its alright? what problems i should look for?
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
