Car just simply dies...WTF? I've tried EVERYTHING!!!
Old May 27, 2002 | 07:14 AM
FLO_BOY's Avatar
It's getting dangerous now...my car will "pull", "struggle", "hesitate" at almost any speed, and will often DIE when waiting at a light, or as I'm driving
What I've done so far:
Changed my PCV
Changed my Fuel Filter
Changed my Engine Coolant Temperature Sensor
Cleaned my Throttle Body
Cleaned (sorta) my Idle Air Control Valve
What's next:
Check my Mass Air Flow Sensor
Check my Throttle Position Sensor
What makes me EXTRA mad, is that i can find many others on here with
the exact same symptoms, and NONE OF US can figure this out...
This is getting out of control -- PLEASE HELP!!!
Thanks!
FLO_BOY
Old May 27, 2002 | 07:54 AM
97GLE's Avatar
Are you throwing any codes?
MIXXMAX's Avatar
Re: Car just simply dies...WTF? I've tried EVERYTHING!!!
Changed my PCV
What's next:
Thanks!
FLO_BOY
Could be a faulty Mass Air Flow Sensor? Just make sure that this is the case. It's a fairly, expensive part.
Old May 27, 2002 | 08:05 AM
FLO_BOY's Avatar
The other day, I received a MAFS code...hasn't repeated itself...
need to check with a multimeter...
FLO_BOY
Old May 27, 2002 | 08:35 AM
got rice?'s Avatar
while you're in there, clean the connectors and make sure the connection is secure.
any fuel smell in the engine compartment when it dies?
Old May 27, 2002 | 08:56 AM
MrBlank's Avatar
Plugs?when did you last change your spark plugs?
Old May 27, 2002 | 09:44 AM
FLO_BOY's Avatar
No fuel smell...thanks for the input!
FLO_BOY
Old May 27, 2002 | 09:49 AM
FLO_BOY's Avatar
maybe a year ago...less than 20K miles...
FLO_BOY
Old May 27, 2002 | 11:30 AM
Toolrocks's Avatar
Make sure you don't have any way for air to enter the engine after the MAF. My car had similar symptoms and it was because the PCV hose the connects to the front cylinder bank developed a gash in it and was letting unmetered air into the engine. Also, like you've all ready mentioned I would check the throttle posistion switch. Good luck and let us know any success.
Old May 27, 2002 | 11:45 AM
NYCe MaXiMa's Avatar
could be the fuel pump.. my fathers car was doing the same thing, then finally it just went out permanently and never started again. Sounds like it can be a problem with the fuel system as well, which is really broad, i know... but maybe you can get the injectors cleaned, also check the fuel lines for leaks or maybe they are clogged somewhere, good luck
Old May 27, 2002 | 03:25 PM
ripper7's Avatar
TPS how to
Just in case you need, her a how to.
http://vbxmaxima.8m.com/tps.html
Old May 27, 2002 | 03:30 PM
mzmtg's Avatar
Minister of Silly Walks
Sounds like a faulty MAF or an intake leak downstream of the MAF.
If air gets into the intake downstream of the MAF it will run very poorly, as you've described. Cheack all your connections, clamps, and bellows between the MAF and TB. Also, check all your intake manifold gaskets, they could be leaking as well. (Ming knows about this with his chromed upper manifold...)
Old May 27, 2002 | 03:56 PM
kvzeyde's Avatar
Does engine temperature make a difference?
FLO_BOY It's getting dangerous now...my car will "pull", "struggle", "hesitate" at almost any speed, and will often DIE when waiting at a light, or as I'm driving
Does the engine have to warm up before it starts acting up?
Old May 27, 2002 | 04:18 PM
Pappa Grande's Avatar
Re: Does engine temperature make a difference?
This will be hard to explain but here we go:
When I check my ECU for trouble codes, the littls screw you turn on my car never stops turning - so basically I could turn it all day long. After turning the screw clock wise, if I don't turn it back (counter clockwise) the same number of turns my car will just die after I start it up - unless I keep the foot on the gas:
So my question is - how careful were you when you checked your ECU for trouble codes? did you over turn the screw? If so you should try turning your ECU screw counter clockwise a couple of turns...
Sorry if that wasn't clear ...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Slamrod
Apr 10, 2016 05:24 PM
District
Aug 15, 2015 08:23 PM
Balkins
Aug 12, 2015 06:39 AM
