how do I test my MAFS?
Old May 27, 2002 | 08:26 AM
FLO_BOY's Avatar
All help is appreciated...I've searched, and all I ever find is people
saying "You should test your MAFS"...OK smart-guy, how do I do it?
THANKS!!!
FLO_BOY
Old May 27, 2002 | 08:31 AM
FLO_BOY's Avatar
Re: how do I test my MAFS?
THANKS!!!
FLO_BOY
Also, I know I'll need a multimeter, so, where and how!
Old May 27, 2002 | 08:34 AM
elcid's Avatar
Re: Re: how do I test my MAFS?
Ya I want to know how to do this ish also.
Old May 27, 2002 | 08:51 AM
Ravq's Avatar
It is very easy to test the MAFS all you need is a voltmeter or multimeter to check the voltage while engine is off and key is at "ON" position. You'll need to backprobe terminal one (left most connector) on the plug. It should be less than 1.0 volt. With the engine idling at operating temp is should be 1.0-1.7 volts. With the engine running at ~2,500rpm it should be 1.5-2.1 volts. You should observe a linear voltage rise in response to increses in engine rpm up to about 4k. If voltage is within spec you can also check the power and ground circuits.
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
