car will die every now and then
Old May 28, 2002 | 07:36 PM
95BlackMax's Avatar
only when i come to complete stops and its not all the time my max will die. one of my valve cover gaskets was leaking so i replaced both and the little "O" rings in the valve covers also as far as i know the leak cleared up but my car still dies any ideas, i thought that it would be a sensor but my check engine light only gives me my engine coolant temp sensor. could that be it. oh yeah im going to replace the sensor anyway
thanks
Old May 28, 2002 | 08:02 PM
1FSTMAX's Avatar
Re: car will die every now and then
thanks
Have you tried cleaning you throttle body?
Old May 28, 2002 | 08:14 PM
gabuchu's Avatar
Does it die only when it is cold? If so then there is a good chance it is the coolant sensor.
thanks
Old May 28, 2002 | 09:01 PM
SuDZ's Avatar
When was your fuel filter last changed?
SuDZ
Old May 28, 2002 | 11:20 PM
95BlackMax's Avatar
SuDZ
well i posted this earlier tonight and well it did something that it has never done. i was doing about 60 cruzin at 2k RPM and all of a sudden my max started jumpin. i played with it for a while and it would only do it when i barely popped the gas it was just spariticly poppin. then i turned the corner and was going about 10 or 15 and it died agian. cranked it back up reved to redline and everything was working fine again. my check engine light says line pressure control valve (automatic). no i havent cleaned my throttle body and my filter hasent been changed either. could there be anything else that im missin???
Old May 28, 2002 | 11:27 PM
MAX95RUS's Avatar
Replace your coolant temp. sensor
Old May 28, 2002 | 11:30 PM
95BlackMax's Avatar
oh yeah everytime it dies its at regular temp...
Old May 28, 2002 | 11:54 PM
MAX95RUS's Avatar
http://forums.maxima.org/showthread....hreadid=116457
I had similar symptoms as you described, including high speed RPM jumping.
Old May 29, 2002 | 07:08 AM
JeepRage's Avatar
I saved last post, I'll save you too. It really is the Temp coolant sensor. Mine was the same way, but my check engine light never went off. The fact that yours did, its a grauntee. Don't question it, it all makes sense when you think about what the sensor does. Replace it, and you will be all set.
Hall
Old May 29, 2002 | 07:57 AM
ripper7's Avatar
I had the same problem, it was the engine coolent temp.
There is a thread somewhere on this site explaining what the ects does but i can't remember where it is... do a search.
Mine sputter, when i tried reving the engine it blue out smoke and then stalled. Clean the throttle body, then change the ects ($36 from dealer). If I can find the thread i will post it here.
95BlackMax's Avatar
Hall
thanks everyone for the info
Old May 29, 2002 | 10:17 AM
cmac95gxe's Avatar
Maximaniac
I have the same problem with my max stalling and jumping. I'm gonna replace the coolant sensor as well as the knock sensor. I'll post once its been done.
Old May 29, 2002 | 10:29 AM
FLO_BOY's Avatar
FYI -- I've had that problem too -- I've changed both those sensors, to no avail!!!
FLO_BOY
Old May 29, 2002 | 07:46 PM
cmac95gxe's Avatar
Maximaniac
[QUOTE]Originally posted by FLO_BOY
[B]
Really? Did you find out what the problem is?
Old May 30, 2002 | 06:53 AM
FLO_BOY's Avatar
[QUOTE]Originally posted by cmac95gxe
[B]
NO
I'm starting to think its either my TPS or my fuel pump...In any case,
I will let you know -- but, I think the important lesson here is don't change
things unless you know its broken, unless you want to do it as part of 'maintenance'.
I'll let you know what happens -- I want to test my TPS, but I just
haven't had the time.
best,
FLO_BOY
Old May 30, 2002 | 07:34 AM
cmac95gxe's Avatar
Maximaniac
Thanks, I'll keep that in mind.
Old Jun 6, 2002 | 04:01 AM
magic_max's Avatar
TPS Problem
Symtoms:
Rough idle in park and drive. Car rpm will sporatically drop to below 500rpm. Rarely feel anything going 50+mph.
Solution:
After doing a search and reading the post on rough idle, the Throttle Position Sensor (TPS ) seemed to be the closest to my problem so I deceided to investigate it. I followed the Haynes manual and determined I need to replace my TPS. The resistance values did not match the manual. However, since I did not have time to purchase one, I deceided to adjust the TPS to match what the Haynes manual says. After adjusting it to the best that I could, my car idled a whole lot better for the first couple days and now it came back but still not as bad as before. I'll hunt around for a replacement TPS and buy it then. I hope this helps someone else as this forum helped me out.
~magic_max
'96SE
Old Jul 2, 2002 | 04:56 PM
t0mt0mboy's Avatar
my car dies every now and then as well...recently i just changed the coolant temp sensor...thought it fixed the problem...this was yesterday...then today i made a turn at about 10-15 mph...then it just dies...good thing there wasn't any car around...so does anyone knows what's the problem...i don't wanna bring the car to the dealer to charge ya all that labor and maybe for just something you can fix on your own...i got a autoshop to check on the alternator...they said it was fine...someone help
Old Jul 2, 2002 | 05:12 PM
FLO_BOY's Avatar
search!!! I've got ATLEAST 10 posts on this from my own experience...
could be a number of things...just go through the list.
FLO_BOY
Old Jul 2, 2002 | 10:30 PM
95BlackMax's Avatar
well i finally got it fixed... my cel would stay on and give me all kinds of messages... i ended up replacing my engine coolant temp sensor but the code was still there even though i reset the ecu. so i dicided to take it to the dealership and just so happens that my efi wiring harness had a couple burnt wires... anyway got it fixed and no more prob. plus the cel went away and everything works perfect now. hope that helps
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
