Still experiencing low idle @ 500 RPM
Old May 29, 2002 | 12:34 PM
maxnewbie's Avatar
I am still experiencing low idle at 500 RPM. Changed fuel filter, cleaned TB, IACV, replaced KS (was getting error), replaced PCV valve, replaced air filter. Have not changed spark plugs yet (that will be next). Have I missed anything? I have regained low end HP when I replaced KS and have more high end power. No error codes showing up now except 0505 (which is everything OK). Should I consider changing the ECTS (engine coolant temp sensor)?
Old May 29, 2002 | 12:47 PM
AdMax98's Avatar
Re: Still experiencing low idle @ 500 RPM
Just making sure...have you reset your ECU? When I was fooling around with my homemade upper intake, it started dipping down below 500 at idle, even with everything attached. Then I reset the ECU and it was all back to normal.
Old May 29, 2002 | 12:54 PM
maxnewbie's Avatar
Re: Re: Still experiencing low idle @ 500 RPM
Yes I did.
Old May 29, 2002 | 01:08 PM
sparkymax96's Avatar
What year is your car?
You might be right about the coolant sensor...
Old May 29, 2002 | 01:12 PM
maxnewbie's Avatar
97 GLE 51,000 miles. How do I reset the ECU?
Old May 29, 2002 | 09:11 PM
tom_98se's Avatar
What about adjusting manually?
Maybe I'm an idiot, but what about simply adjusting the idle manually?
Check out this post about adjusting abnormally high idles - http://forums.maxima.org/showthread....threadid=99586
About a third of the way down, Confused outlines the difference between the idle adjustment and the idle stop screw (apparently a significant issue.) Per him, "The idle adjustment screw is on top of the IAC valve (right rear of the upper intake manifold)." COuldn't you just crank it up a bit?
Good luck,
TOM
bryants95max
Oct 2, 2015 12:52 PM
lrb6805
Sep 17, 2015 04:49 PM
dcardello
Sep 3, 2015 11:44 PM
