ecu code 07/02
Old Jun 1, 2002 | 08:45 PM
Dahnryman's Avatar
ecu code 07/02
Three Way Catalyst (right bank)?
o2 sensor? right side rear..? or after the cat...i know the left bank is the farthest to the front on the y? can anyone give me a little knowledge on this>
Old Jun 1, 2002 | 08:46 PM
Dahnryman's Avatar
and for the flamers....
Yes i used the decoder......
Old Jun 2, 2002 | 06:36 AM
iwannabmw's Avatar
DTC 0702
Diagnostic Trouble Code 0702 points to a problem with the three-way Catalytic Converter.
The Cat is one of the principal components of the emissions control system. The Engine Control Module monitors the signals from the two front Oxygen Sensors and the one rear Oxygen Sensor. The signal frequency of each sensor indicates something about the condition of that sensor. A comparison of the frequency of the front sensors with the rear sensor indicates something about the condition of the Cat.
This malfunction was detected when the ratio of the signal frequency from the right bank front Oxygen Sensor to the signal frequency of the rear Oxygen Sensor exceeded a critical threshold value. This indicates that the Cat does not have enough oxygen storage capacity. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5.
Possible causes of this DTC include ...
- Three-way catalyst
- Exhaust tube
- Intake air leaks
- Fuel injectors
- Spark plugs
- Ignition timing
Old Jun 2, 2002 | 07:27 AM
dwapenyi's Avatar
Usually it's a sign that you cat is not working properly.
DW
Old Jun 2, 2002 | 07:32 AM
Dahnryman's Avatar
Could my RT cat be causing it
DW
i do have a random tech cat....but its been on for 5 months....
Old Jun 2, 2002 | 08:09 AM
dwapenyi's Avatar
Re: Could my RT cat be causing it
You know what? So do I. I actually started getting 0702s when I put my Y pipe on with the RT Cat. I'm in the process of doing the final upgrades to my exhaust. I'll put my stock cat back on when I put in my B pipe and muffler.
DW
Old Jun 3, 2002 | 04:31 PM
Dahnryman's Avatar
i have full
i have full exhaust upgrade....y,cat,b,coffee can muffler...all installed since dec. I reset the ecu and drove it moderatly then hard no light so i think im ok.....i also have my air/fuel guage hooked up to that sensor.....yah i know whould of done the front one....but it works fine.....
thanks for the info guys....
Old Jun 3, 2002 | 08:00 PM
dwapenyi's Avatar
Drive like a granny for an hour or 2. 0702 comes on from light throttle, not WOT. Ask me how I know
DW
Old May 22, 2004 | 10:55 AM
2maximas's Avatar
my 0702 came on from HARD acceleration!?!?
Old May 22, 2004 | 10:57 AM
2maximas's Avatar
OH and I just put on a "test pipe" which includes a resonator in it, got it off ebay and it is built VERY nicely. welds are perfect.....looks just like a row of nickles....as it should.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
