Low idle in "R"
Old Jun 4, 2002 | 04:54 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Low idle in "R"
When going into "R" my idle goes as low as 400rpm and I can feel the engine shake, is that normal?
This is w/ an Auto. trans
Old Jun 4, 2002 | 06:30 AM
mango95se's Avatar
Re: Low idle in "R"
this won't help much, but i have the same problem. Any ideas?
Old Jun 4, 2002 | 08:29 AM
njmaxseltd's Avatar
The low idle only happens in "R"? In "D" your ok?
This is a wild guess -
Your ECU must adjust the idle speed to compensate for the slight load on the engine when your car is in gear. So perhaps the switch or signal from the shifter which alerts the ECU to R,D,2,1 isn't working in the "R" position.
I'll check the Haynes manual to see if there are references to signals or switches on the shifter or the tranny.
Old Jun 4, 2002 | 09:44 AM
FLO_BOY's Avatar
try cleaning your throttle body...
and idle-air-control valve...when these get dirty, and your car is in the low RPMs, the engine struggles a little because of the dirt.
give it a try!
FLO_BOY
Old Jun 4, 2002 | 10:12 AM
mango95se's Avatar
Re: try cleaning your throttle body...
My throttle body is clean, but how do i clean the IAC? I did a search on here and couldn't find anything. Do i just shoot throttle body cleaner into the IAC inlet tube?
give it a try!
FLO_BOY
Old Jun 4, 2002 | 10:37 AM
FLO_BOY's Avatar
Re: Re: try cleaning your throttle body...
Yeah, I was confused about this one too...when I went back, I noticed that the IACV sits in a "bracket" with three bolts...its pretty simple when you take a good look at it.
When I cleaned mine, it was FILTHY!!!!
sorry I can't give you more advice, but, if I get pics, I'll post!
take care,
FLO_BOY
Old Jun 6, 2002 | 04:31 PM
Yep, just in "R". "D" I'm ok, Idle is about 500-600rpm in "D"
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
