Anyone have speedbleeders? ( questions for you)
Old Jun 7, 2002 | 08:13 AM
Kevin's Avatar
Don't you still need two peopl to bleed the brake likes? someone to pur in the fluid while someone else pumps the brake? also how hare are they to install? anny leaakage from installing?
Kevin
Old Jun 7, 2002 | 08:19 AM
ejj's Avatar
ejj
Re: Anyone have speedbleeders? ( questions for you)
Kevin
Don't need 2 people, but it would make things quicker.
Install is easy. Take out old bleeders, screw these in. No leaking.
Old Jun 7, 2002 | 08:29 AM
dwapenyi's Avatar
I have 'em. It can be a one person job. Also when I do it, I try to flush out all the old fluid, not just get rid of the air in the system. This is what I do;
1. Make sure the brake reservoir is full.
2. Open one bleeder up.
3. pump the brake pedal about 17 times, that's usually enough to almost empty the reservoir. I say almost, DO NOT empty the reservoir, just get it down to the low level.
4. Lock up the bleeder,fill up the reservoir.
5. Pump brake again to make sure things feel solid and no air is left in the system.
Then onto the next brake, repeating steps 1 thru 5. You should do it in this order, too;
Right Rear
Left Front
Left Rear
Right Front
DW
Old Jun 7, 2002 | 08:33 AM
Kevin's Avatar
Right Rear
Left Front
Left Rear
Right Front
DW
thanks, this is good intruction. Ths shold go in the FAQ if it isn't already there.
Kevin
Old Jun 7, 2002 | 04:09 PM
PhatBastard's Avatar
Make sure you get GOOD speed bleders like Russell, especially if you have SS brake lines.
The HELP! brand that you can get at any Pep Boys or Autozone SUCK A$$!
I literally blew out two of them just flushing out the break lines in my driveway.
Old Jun 7, 2002 | 04:15 PM
Jeff92se's Avatar
I'm needing a caw
Better.
http://forums.maxima.org/showthread....essure+bleeder
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
