need help bad
Old Jun 7, 2002 | 05:36 PM
camaro1698's Avatar
need help bad
Alright guys I've tried everything and get my max to work right. The has a very rough idle only when there is load on the vehicle, like when the car is in drive or reverse. The car sounds like its going to stall but it never does. Also, it doesn't happen right when you start the car. The car to warm up first and then it occurs. I've cleaned the throttle body, changed the plugs, changed the coolant temp sensor, changed the throtle position sensor, changed the iacv valve, changed the front oxygen sensors. There are no trouble codes coming up either. Any suggestions on what it could be?? its a 95 max by the way with 123K on it.
Old Jun 7, 2002 | 06:15 PM
camaro1698's Avatar
what the hell does that mean!!!???? isn't this board for help with a maxima and a wisdeguy forum!
Old Jun 8, 2002 | 09:03 AM
ladeesman's Avatar
I've seen the same symptoms on my mom's Max. Turned out it was a problem with the EGR port/valve. I couldn't diagnose that myself, dealer took care of it.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
