installing air/fuel and tranny temp gauges
Old Jun 11, 2002 | 08:15 PM
Jamsan's Avatar
how are these 2 gauges installed...i dont mean physically into the pod, but what wiring is necessary....ive done a search, so please dotn say search is your friend
Old Jun 11, 2002 | 08:24 PM
Nismo87SE's Avatar
The trans temp will need a Tee inbetween one of the return lines from the radiator (you should install a trans cooler too). That is assuming its an electric gauge, if its mechanical just run the line through the firewall to the place where you want to put the Tee.
As for the A/F ratio return it and get your money back, oil pressure is alot better than a sub $300 A/F ratio gauge.
Old Jun 11, 2002 | 08:28 PM
Jamsan's Avatar
well i havent bought any of these yet, just those were my 2 most probable ones....whats the oil pressure one do??....also, i am going to get a tranny cooler as well, but i want to get the tranny gauge first to see what kinda temps it goes down
Old Jun 11, 2002 | 08:40 PM
1MAX2NV's Avatar
I like pictures.
Tranny temp gauge probe manifold.
http://photos.imageevent.com/1max2nv...e/DCP01060.JPG
Oil pressure line.
http://photos.imageevent.com/1max2nv...e/DCP01032.JPG
This is what's at the other end. A tee and one is the OEM oil pressure switch and the other end is the autometer oil pressure sender.
http://photos.imageevent.com/1max2nv...e/DCP01030.JPG
http://photos.imageevent.com/1max2nv...e/Dcp01004.jpg
Old Jun 11, 2002 | 08:42 PM
Jamsan's Avatar
ok wow that looks complicated....
Old Jun 11, 2002 | 09:52 PM
FlAWD96SE's Avatar
Originally posted by 1MAX2NV
I like pictures.
Oil pressure line.
ok......where in the engine are thoes located? i c the oil one but the others?
Old Jun 12, 2002 | 07:08 AM
1MAX2NV's Avatar
Tranny temp probe manifold is located between the outlet line of the auto tranny and the inlet of of the OEM tranny cooler. The tranny temp probe manifold setup is actually pretty simple. The oil pressure probe is a bit complex.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
lux97Max
Sep 4, 2015 05:42 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
