Car is Shaking!
Car is Shaking!
About 2 months ago I was in an accident and ever since the accident my car has been shaking at speeds between 60-80 mphs. Before the accident I got my breaks but on and they said I had abour 3000 or so miles left on my rotors before they go bad. There are so many things that it could be. I need some advice on what the problem could be.
Re: Car is Shaking!
Cashj2002
You need to be more descriptive in the type of accident so we might be able to give better suggestions.
I'm going to assume you had a front-end/side accident. Was there any contact with your wheels (with the curb, car, etc). What type of repair was done?
Could your wheels be out of balance? Have you checked your alignment? A possibility is that your drive shaft or linked components might have bent slightly such that it appears straight but speed has a way of brining out the faults.
Re: Re: Car is Shaking!
Well the accident didn't get past the front bumper, it didn't get near my rims just the hood was messed up. The bumper had little nicks not bad. People are telling me if could be bad rotors I need to see if the right weights on are on rims, that one of my tires are going bad. etc
Re: Re: Re: Car is Shaking!
Bad rotors will only cause vibration when you're braking.
Weights on the wheels (I'm assuming that's wheel balancing) and that could be a culprit.
Inspect your tires, make sure there's no worn spots (emergency braking and dragging tires) or splits, thread damage, etc.
Re: Re: Re: Re: Car is Shaking!
same thing happened to me....i was actually gonna post today, but i got carried away with some other things, and well i come home, and you post my exact symptoms
....well about a year ago, i got into an accident, and my front right axle snapped and the tire got pushed back into the firewall....ever since then, non stop shaking from 60-80....also the car veeres slighlty to the right on the highway....i took back 2 times to the mechanic, and still the same ****.....they said it was the alignment, but the ****ign dumbasses havent fixed it yet.....get your alignment checked first, becasue i think thats what it could be
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
