Idle Air Valve Cleaning
Old Jun 13, 2002 | 10:04 AM
96SE_dsm's Avatar
FYI
I have a 96SE with approximately 69K miles that was experiencing uneven accereration during light loads. I replaced my fuel filter with no improvment when I first experience uneven acceleration.
The idle speed begain sticking at 1500rpm when returning from higher engine speeds. So...I removed and disassembled the air intake valve and used carb cleaner to clean 'gunk' from valve assembly.
The coils for the valve motor can be separated from the magnet and valve. I cleaned components and re-assembled.
Accerlation is now smooth and idle speeds are stable.
Hope this helps others with similar problems.
Old Jun 13, 2002 | 10:22 AM
FLO_BOY's Avatar
Re: Idle Air Valve Cleaning
Originally posted by 96SE_dsm
FYIThe idle speed begain sticking at 1500rpm when returning from higher engine speeds. So...I removed and disassembled the air intake valve and used carb cleaner to clean 'gunk' from valve assembly.
I would use "Throttle Body Cleaner" instead of "Carb Cleaner"...
my $0.02
FLO_BOY
Old Jun 13, 2002 | 10:53 AM
njmaxseltd's Avatar
96SE-dsm - You should insert this info in the FAQ section. It's very good information that a lot of people on here could use. Take your credit man.
Old Jun 13, 2002 | 10:58 AM
96SE_dsm's Avatar
Re: Re: Idle Air Valve Cleaning
my $0.02
FLO_BOY
What is the difference?
Old Jun 13, 2002 | 11:05 AM
elcid's Avatar
Re: Re: Re: Idle Air Valve Cleaning
For sure man, you should do a write up and put it in the FAQ, just as mentioned above so you get your credit. I've read tons of posts which I'm sure this would solve their problem. You would help out the forum ! Good stuff man!
Old Jun 13, 2002 | 11:13 AM
Max96's Avatar
Dude! Thanks for the tip. I have been having the same problem, and was pointing a finger at the air intake valve. Now I know for sure thats what is causing it. THANKS!
Old Jun 13, 2002 | 11:27 AM
FLO_BOY's Avatar
Based on the research I did on this site, everyone told me to not to use carb cleaner, and to instead use throttle body cleaner...something
about the chemicals...
FLO_BOY
Old Jun 13, 2002 | 11:35 AM
96SE_dsm's Avatar
Re: Re: Re: Re: Idle Air Valve Cleaning
FLO_BOY
GOOD POINT.....
Be careful not to expose O-ring in assembly to the cleaner.
Also, check the Haynes Manual page 6-18 for reference.
Smackasmith
Feb 1, 2016 12:40 AM
tgreen
Oct 18, 2015 06:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
03VQMAX
Sep 5, 2015 03:47 PM
sdotcarter
Sep 2, 2015 09:53 PM
