I installed custom intake
and now the service engine light is on
MY CAR SUCKKKKKKKKKKKKKKKKKKKSSSSSSSSSSSSSSSS
i love my car but damn it, its causing soo many problems
and im sooo broke
i put the intake on and that piping
i put the breather
i dont know the problem!!!!!!!!!!!!11
anyone with any problems similar
and im sooo broke
i put the breather
Re: I installed custom intake
and im sooo broke
i put the breather
and im sooo broke
i put the breather
Did EVERY hose/sensor get a good home?
Custom huh.. double check to make sure it ain't loose?
Rest ECU? Come back?
try checking the ECU for codes...if its 0102 (MAF), then just recheck your connections and see if there is any leaks, and then reconnect all the hoses and connections.....its probably nothing to worry about
You broke it? ie, the car is not functioning the way it's suppose to, or the CEL engine came on.
My CEL is always on
.. Broken rear O2 sensor. No big deal. However, I've also had the CEL come on during my intake install, and it's because I took my MAF sensor apart and when I put it back together again, the prongs inside got a little bent out of place and weren't connected properly. The result being: A car that would sputter, gasp, and eventually die after starting it up.
If you're getting the same problem, then it's your maf sensor. I don't recommend tearing it open and trying to fix it, but it can be an expensive part to replace if you have no cash. I had a buddy hook me up with one for $65 (dealership wanted like $3-400). Take a search for broken maf sensors and check how people fixed em if the symptoms you're getting match the above. If it's just the CEL light, pull the code.
My CEL is always on
.. Broken rear O2 sensor. No big deal. However, I've also had the CEL come on during my intake install, and it's because I took my MAF sensor apart and when I put it back together again, the prongs inside got a little bent out of place and weren't connected properly. The result being: A car that would sputter, gasp, and eventually die after starting it up.If you're getting the same problem, then it's your maf sensor. I don't recommend tearing it open and trying to fix it, but it can be an expensive part to replace if you have no cash. I had a buddy hook me up with one for $65 (dealership wanted like $3-400). Take a search for broken maf sensors and check how people fixed em if the symptoms you're getting match the above. If it's just the CEL light, pull the code.
Originally posted by Jamsan
if u wanna reset the cpu, why dont u just turn the screw to the right, then left, then right, and left again??
I feel stupid I did not know that.
It's okay, we all make mistakes. For some reason that's really cracking me up right now. But to get back on topic, I just made an intake also. Read the 4th gen FAQ if you don't know how to reset your CEL. Reset it, and then check the codes when it pops back up. Check your MAF connection, and make sure you didn't damage it when you reinstalled it. Also, there is a rubber o-ring on the filter side of the MAF, make sure it is still there and is making a solid connection with the adaptor (a.k.a. no leaks). The third place you might want to look is where your hose barb and nipple are sticking out of the coupler. Make sure they have a solid seal.
i live in tampa fl
whats a CEL
ill check on the FAQ for what it is... if you know i cant find the CEL's meaning on there please help..
i think i know what the problem is ....
and for the guy that feels stupid that he didnt know that
i still dont know wat right left right left is! soo dont feel stupid
always someone out there stupider! (me)
but im tryin to learn about cars! thanx for help im goign to go check the Hoses right knwo to make sure.. ok byeeee thanx
whats a CEL
whats a CEL
Good luck!
umnitza
Sep 1, 2015 01:03 PM
Maximeltman
Aug 31, 2015 01:01 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
