Speed Limiter?
Old Jun 14, 2002 | 10:37 PM
max2go's Avatar
Speed Limiter?
is it true that a 95 Nissan Maxima GXE have a speed limiter? I only went 115 with my maxima. But never got a chance to get over that.
Old Jun 14, 2002 | 11:09 PM
silvermax2k2's Avatar
i am pretty sure that almost all cars have a speed limiters... i wouldn't suspect anything diffrent with the max... but you have given me another reason to test my top speed out! i'll let you know.
Old Jun 14, 2002 | 11:39 PM
Nealoc187's Avatar
SLOW
Some GXEs have governors at 116 mph. Other trim levels are not governed. Search for "Ben's ECU Mod" to read about how to get rid of your governor if you wish.
Old Jun 15, 2002 | 12:54 AM
Jepht20's Avatar
Custom User Title...
has everyone/anyone who has gotten rid of this who used the switch had success? check engine lights stay off? i'm thinking about doing this and adding that switch from radio shack...but then again, who needs to go over 116?
Old Jun 15, 2002 | 04:57 AM
KINGMAX's Avatar
Re: Speed Limiter?
The GXE and GLE have speed limiters. The SE doesn't, I have gone nearly 140 in mine.
Old Jun 15, 2002 | 05:25 AM
mzmtg's Avatar
Minister of Silly Walks
ONLY some GXE's are limited. The ONLY way to know for sure if you have one is to go out and try. Believe me, you will know if you have one.
How to disable it is covered in the FAQ.
I've had mine on a switch for about a year now. As long as you only switch it "off" for a few mitues at a time (less than say, 15 minutes), you dont get a CEL.
Old Jun 15, 2002 | 07:34 AM
max2go's Avatar
the directions to taking the speed limiter seem so hard. Would a shop be able to do this for me? is it legal?
Old Jun 15, 2002 | 08:01 AM
95emeraldgxe's Avatar
legal - i dont see how you could get in trouble for it......after all, some maximas are allowed to go past 115 already
Old Jun 15, 2002 | 08:31 AM
mzmtg's Avatar
Hard? Snipping one wire is not hard.
Old Jun 15, 2002 | 09:34 AM
THURSTY4NOSMAX's Avatar
Mines used to annoy me!
Well its Illegal to take of the speed sensor off your max,but I did it.Ok im going to give you a hint.Under your intake if you look under it by then fender its a sensor right there.You pull it off and no worries about your miles going up because its not going to work lol.Also your speedometer isn't going to work because your speed sensor cant read the speed your going,thus no more fuel cut,and no more limiter.You didn't here this from me.....
Old Jun 15, 2002 | 09:42 AM
mzmtg's Avatar
It's not illegal to remove the top speed limiter.
The whole point of my mod method is to remove the limiter and keep the odometer, speedometer and cruise control functional. If you unplug the sensor at the transmission, you lose all those functions.
Do you even read threads before you post in them?
Old Jun 15, 2002 | 09:48 AM
I know man!
Trust me I know what your telling me,but I dont want my odometer to work.Thats whats illegal you cant mess with the odometer.I understand you just want to help me man.
Old Jun 15, 2002 | 09:57 AM
Maximum97's Avatar
Re: Speed Limiter?
I hit 135 @ 5600rpm then I ran out of room.
Old Jun 15, 2002 | 10:08 AM
Nealoc187's Avatar
SLOW
Re: I know man!
Thats nice and shady... good way to screw the next person who buys the car. As we can see, some maxima owners have no morals.
Old Jun 15, 2002 | 10:10 AM
Im keeping my baby forever
I just want the warranty to last another year.I'm not doping nobody but shes mines forever!!
Old Jun 15, 2002 | 08:42 PM
max2go's Avatar
Re: Im keeping my baby forever
if you pull the speed sensor out,there is no more speed limiter?
Old Jun 15, 2002 | 08:44 PM
Yes no speed limiter!
Old Jun 15, 2002 | 09:51 PM
dtrain73's Avatar
Re: Re: Speed Limiter?
Yeah I have actually gone 140 in my 1996 5sp SE.
Old Jun 21, 2002 | 01:31 PM
icemax's Avatar
I didn't quite understand if there was or was not a problem with the check engine light staying on, or if there is a chance of damaging the ECU by toggling the speed sensor input to the ECU switch on and off while the car was on. Also, FYI : make sure you have the right kind of speed rated rubber (stock GXEs, for example don't.)
Old Jun 21, 2002 | 01:40 PM
mzmtg's Avatar
The CEL will come on if you disconnect the speed sensor. However, it only comes on after the sensor has been disconnected for approx. 20 minutes (hence, the switch).
As for damage, I have no idea.
Yes, I have good rubber
Old Jun 21, 2002 | 01:50 PM
dwapenyi's Avatar
The reason the limiter was there in the 1st place is b/c that Maxima came from the factory with T rated tires. If you've replaced your tires with H rated or better, like V,Z,W,Y, then remving your limiter is perfectly OK.
Here's a breakdown of tire speed ratings;
N=87 MPH, 140km/h, Spare Tires
U=124 MPH, 200km/h
P=93 MPH, 150km/h
H=130 MPH, 210km/h, Sport Sedans <-----Maxima, baby!
Q=99 MPH, 160km/h, Winter, LT Tires
V=149 MPH, 240km/h, Sports Cars
R=106 MPH, 170km/h, LT Tires
Z=149 MPH, 240km/h and over, Sports Cars
S=112 MPH, 180km/h
W=168 MPH, 270km/h, Exotic Sport Cars
T=118 MPH, 190km/h
Y=186 MPH, 300km/h, Exotic Sport Cars
DW
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
