Double Clutching
Old Jun 15, 2002 | 06:40 PM
Linkage23's Avatar
Double Clutching
I know double clutching can be used to an advantage. Isn't it possible to hurt a vehicle when doing this too?
Old Jun 15, 2002 | 07:02 PM
96BLUMAX's Avatar
I have never heard of damaging a car by clutching twice. Also it in most cases is unnecessary.
Old Jun 15, 2002 | 07:12 PM
njmaxseltd's Avatar
Double clutching was done back in the days when manual trannys didn't have syncros. It was to bring the tranny free spinning gears up to match the speed of the gear you were going into when downshifting.
Somebody correct me if I'm wrong here.
Old Jun 15, 2002 | 07:17 PM
Mad Dhan's Avatar
if you want learn stuff like that try heel/toe - braking/shifting
like njmax said we dont need to double clutch anymore
VQdriver's Avatar
correct. i double clutch all the time. it's fun especially when you can double clutch/heel toe. however, if i were doing laps around a track i would use single clutch heel/toe. when done correctly you know it works when the lever slides into the lower gear with absolutely no resistance and the engine sounds smooth.
Old Jun 15, 2002 | 07:19 PM
densetsu's Avatar
yeah
yeah you're right. the driver would first have to press the clutch to disengage the gear, then release it, and then press it again to engage the next gear. you can do it, but it is pointless because newer transmissions have the synchros but if it makes you feel faster then go for it.
ps if i knew how to quote i would...
Old Jun 15, 2002 | 07:47 PM
runelind's Avatar
Re: yeah
http://integra.vtec.net/driving/dclutch.html
Read it
user 11122324
42
Jul 18, 2022 03:35 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
carlosvq30
Sep 26, 2015 09:44 AM
