how hard was it installing your UR underdrive pulley?
Old Jun 15, 2002 | 07:42 PM
VQdriver's Avatar
there are tons of posts. however, has anyone found it to be easy? it looks and seems like it's hard when reading through these posts.
Old Jun 15, 2002 | 07:43 PM
Nismo87SE's Avatar
if you have a gear puller it isn't hard at all. Its $15 at an autoparts store get it or rent it. Other than the crankpulley bolt being tough to get loose, everything else is easy.
Old Jun 15, 2002 | 07:56 PM
ptatohed's Avatar
Licensed to Spell
:o)
I can't answer for the actual removal of the pulley but it looks like Nismo did a fine job at that. However, in intalling the SC, I had to get under there competely, remove the belt, work near it, etc. so I technically have done all the work that would be needed to change it. And I would say it isn't so bad. Read my instructions for step #9 in my write-up:
http://www.cardomain.com/member_page...=181995&page=5
Good luck.
Old Jun 15, 2002 | 09:06 PM
Iron Lung's Avatar
Re: how hard was it installing your UR underdrive pulley?
It would have been a whole lot easier if I had not broken the belt tensioner bolt. But other than that it was pretty easy.
Old Jun 15, 2002 | 11:14 PM
Dave B's Avatar
Not DAVEB the parts guy
Gear puller? For what? The pulley simply slides on and off once you remove the pulley bolt. Changing out the pulley is very easy assuming you know how to remove the power steering and accessory belt and have a decent breaker bar (ie get a Chiltons manual).
Dave
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
trungg86
Sep 4, 2015 04:58 AM
Johnny9595
Sep 3, 2015 05:18 AM
