doing 60k tuneup
Old Dec 5, 2000 | 08:31 AM
max1ma97se's Avatar
ok i have a 97 i bought new spark plugs, oil, oil filter 5 quarts of redline tran fluid and i was wondering is there a transmision fluid filter do i have to replace it.
Old Dec 5, 2000 | 08:50 AM
SmoothMax's Avatar
OG
I, personally, never heard of a transmission fluid filter. Just click on this link and you'll get all the info you need.
integra.vtec.net/geeser/megamax/60k_service.html
Old Dec 5, 2000 | 05:15 PM
max1ma97se's Avatar
yea there is
i bought it today cost 22 bux at kragen its located in the transaxle i think comes with a gasket for the tran fluid pan too
Old Dec 5, 2000 | 05:29 PM
SmoothMax's Avatar
OG
really?? That's new to me? How often are you supposed to change it?
Old Dec 5, 2000 | 05:42 PM
max1ma97se's Avatar
no clue
im doing part of my 60k now even tho im only at 51k cause my spark plugs were toast performance was horrible. i thought since i was changing my tran fluid might as well change tran fluid filter it look hard to do tho gonna have my friend look at it. the book i have says u have to take yur valve body off and tht sounds complicated but i guess its worth it only gonna do it once wanna make sure next person owns this car dosent have to worry about any thing
Old Dec 5, 2000 | 06:15 PM
humaras's Avatar
responsible owner
very impressed...I am very impressed...it is very good citizenry of you to be thinking of that.
I am not sure if there is a filter. Then again, I feel that I can't believe everything Nissan tells you. I took my car to the dealer for the 30k tranny drain and fill and they laughed when I mentioned "tranny filter" (lousy idiiots--I'll show them and be a maximaniac)
If there is a filter in there--it might be difficult to get too...
where is Mr. Daniel Martin --the night is young...he'll show up and the resident guru will field these questions for us once and for all.
Old Dec 5, 2000 | 07:47 PM
Daniel B. Martin's Avatar
Re: responsible owner
Originally posted by humaras
... ... I am not sure if there is a filter. ...
My own Maxima has a 5-speed. I cannot address this point from personal experience, so I went to the book. The '99 Maxima factory service manual refers to an "oil strainer" which is bolted to the control valve assembly. They don't call it a filter and nowhere do they recommend replacing this part. If my car had an automatic transmission I would change only the fluid and be content with that.
Old Dec 5, 2000 | 08:41 PM
Zprime's Avatar
ok...here is what little I know
there is a filter....but does not really need to be replaced....errr ...I might be wrong...all you need to do for it is flush it or something.... (OK I might be dead wrong)....but that is what I read somewhere...
and then there is the transmission gasket...ok..someone mentioned this were metal..because I asked if I need to replace them...and they said it is made of metal....
err ok....this is nissan tech rep....
Oh well.....
I dunno....just passing what I know...and somebody please correct my mistakes..thanks...
Old Dec 5, 2000 | 08:45 PM
Jason96GLE's Avatar
A Little Confused
I just bought my maxima and I am preparing to do a tranny fluid change in my auto trans. According to my Chiton Total Care manual there is a filter that is replaceable once the pan is dropped. They have pictures showing it. It look like a standard auto filter. Furthermore, I checked CarParts.com website and they sell auto trans filter kits from 4 manufacturers ranging in price from $15-$20. That is the usual price for for a filter and gasket. I thought the only cars w/o replaceable filers were Hondas?
Can a member with an auto who has taken the pan off please let us know.
Also at 60K its a good idea to change to coolant, fuel filter, air filter, and PCV valve along with the trans fluid and oil.
If you are switching to redline it is a good idea to have a system flush at Jiffy Lube as Daniel Martin suggested in other posts. A do-it-yourself change only removes about half the fluid and it would be a shame to mix old Dexron w/redline.
Old Dec 5, 2000 | 09:22 PM
max1ma97se's Avatar
yup
yea i have clintons manual too yea it requires taking off the valve body u know i dont know if u have to replace the dang filter for tran but u know wht better safe then soory escially with a expansive *** thing like a tranny. also with the gasket u should replace that on the tran pan and clean out the pan using a sovalant and clan the magnet in the pan again i dont know ne thing my friend said i should do this his word like mine better safe then sorry. o yea about the gasket being metal go sock tht fool in the face gasket are either the glue stuff or rubber lookin thing it makes a seal if u dont have a seal....
Matt93SE
May 24, 2019 02:58 PM
Jay556
Sep 12, 2015 05:50 PM
Tha'-Max
Aug 30, 2015 01:14 AM
Monil
Jun 13, 2001 12:59 PM
