How to install a front strut bar?
i searched but i really couldnt find somem goor directions on how to install a front strut bar. I just ordered one off of ebay and i wanna know hoe to install it when i comes here. thanx so much
Re: How to install a front strut bar?
http://integra.vtec.net/geeser/megamax/bars.html
Originally posted by njmaxseltd
Don't forget that the 3 nuts on the strut mounts should only be torqued to 35 - 40 Ft. Lbs. Don't over torque them or you can damage the strut mount.
Originally posted by hockeyghst
i just got my FSTB today and i installed it tonight.....i dont have a tourqe wrench so i jus tightend them down.......what happens by not tourqinig them down correctly??? i have done a lot of work on ym car and i have never tourqued any of the bolts when i was putting everyhting back together ex. struts/coilovers......well hopefully someone can give me some good info on how bad not tourquing is.
Put down a deposit, use a tool, return it, get your deposit back.
Or better yet, just spend the $20 for a torque wrench.
And it's scary that you've never torqued down anything you've put in your car.
hmmm ebay!!
I ordered mine on ebay to about a week an a day ago, from "autobacs" has anyone else ordered one from them? I mean i know most fstb are the same and your basically only paying for the sticker on it. Just curious, also where the hell did you see a torque wrench for 20 bux? maybe its just me and the autozone here but they are a little more than that. Aside from that with the fstb, if you over torque or don't use enough, you run the risk of rub off, or whatever you wannt call it basically to loose and the job it is supposed to do wont work to its full potential, and to tight and you might rip the bolts on the strut mounts taking a fast turn or something, which seems highly unlikely, but it has happened.
Originally posted by lefty
I bought a cost effective tourque wrench for $15.00. It is cheaper in quality but it is better than guessing. It has this pointer that when you turn the wrench, it points to the LBS.
Well worth the $$$.
K.
Well worth the $$$.
K.
Where can you get one of these? Wherever you can buy tools. Or you could use the search function on here.
Ebay seller
"btnz" is a good guy to deal with. Easy install for his FSTB, it's generic and $32 shipped. It's on mine and a very noticeable difference in handling. I can't justify the extra $100 for the stillen bar other than to support a .org member trying to sell them either personally or as a business.
those torque specifications from the factory were carefully designed and tested by the top auto engineers in the world . although the factory always trying to find a way to reduce the cost, finding the correct torque is not one of them. without the correct torque, there is no quality in the car. never know when something gonna break or even someone gonna die cuz the wheel fall off. it's like Geo vs. Toyota. by the way, does anybody know toyota use $100,000 (or $10,000) liquid torque wrench or something? that's what I saw in the toyota ad in the mag. but it's just an ad.
I got my torque wrench from autozone for $18.95. and not those you see in haynes (with a pointer or something) it's adjust from the bottom by turning the ***. I guess the place I live has a lower living cost.
MaxStock
08-14-2015 10:01 PM
Greenmaxspeed
08-08-2015 12:39 PM
laparka66
08-06-2015 09:36 AM
