Hit a huge pot hole, damaged 2 Konig's and blew a shock. What do i do now??
Old Jun 17, 2002 | 08:02 PM
perfectmax's Avatar
Well, the MAX isn't so perfect anymore. It never fails, I get a few new mods put on the car and the rear main seal goes and then the A/C compressor, and now this. Oh, i was just about to put in an order for a NX nitrous kit and all the goodies.. DAMMIT!!! Anyway, I hit a HUGE pot hole on the highway (202 south in PA). There was absolutely no way to avoid this thing because of all the construction. I damaged my Konig Monsoons (which I love) and blew out my front KYB AGX front shock. The tires didn't blow out and the center of the rims are fine. Is there anyway that I can get these things banged out so they look 100% again? Do I have to get the tires rebalanced? Also, any of you guys ever had this happen with the KYB AGX's? What do I do and can I just buy 1 or do I have to get a set? Are they covered under warranty? How much do you think this is going to cost? Any advise is appreciated!
Old Jun 17, 2002 | 08:13 PM
JAY25's Avatar
Re: Hit a huge pot hole, damaged 2 Konig's and blew a shock. What do i do now??
Are the KYBs less then a year old? if they are less then a year old call KYB and tell them one of their shocks blew. If they are more then a year old then your just going to have to buy one. Thats the downfall with KYB no lifetime warranty.
Old Jun 17, 2002 | 08:18 PM
perfectmax's Avatar
Less than a year old! Should i ask that both the fronts be replaced? Think that i can get them to pay for labor since i dont have the time right now to do it myself?
Old Jun 17, 2002 | 08:35 PM
Redmax's Avatar
Redlinemax Owner
call your local highway administration and they may reimburse you for the repair
Old Jun 17, 2002 | 09:05 PM
pocketrocket's Avatar
I second that ... take pictures of the damage, and the pothole. If possible, take a measuring tape and measure its depth, width, etc (if you run the risk of getting run over, don't do it or do it faster).
Call up your road commission and tell them you wish to lodge a complaint of vehicle damage due to a pothole.
Old Jun 17, 2002 | 09:37 PM
rmb's Avatar
rmb
You can ask but:
They'll only pay for the one that's actually damaged after you remove it and ship it to them with the proper RMA #. They then inspect it. This will take 2-3 weeks if you're lucky. They will not pay for labor to reinstall it.
I wouldn't mention the pothole if I were you.....
-RMB
Old Jun 17, 2002 | 09:38 PM
iansw's Avatar
Here in Seattle there is a place that will fix aluminum rims...they've fixed my TSW's twice now for only about $75.00 per rim.
Looks good as new.
See if you can find a place like that in your area...My shop is a very small shop that doesn't advertise much...I found them by asking the guys at the big tire store (Les Schwab), and they recommended them.
IanS
Old Jun 17, 2002 | 10:03 PM
puremax's Avatar
it's pay back my friend because you ran from the po po. What goes around comes around.
Old Jun 17, 2002 | 11:58 PM
finny's Avatar
where in pa were ya at? and i have monsoons too and screwed one of mine up so i know how ya feel
Old Jun 18, 2002 | 05:10 AM
euromaxima's Avatar
take pictures and measurments today
my friend hit a pot hole and blew out a tire and a bent rim and when to the state depaartment and told them about it and they already went and patched the hole and told him there was no hole in the road...just go to your state department and file the complaint.
hope everything works out for you
brandon
Old Jun 18, 2002 | 05:16 AM
caneyebus's Avatar
what to do
well the first thing to do is CRY than get em banged out and buy a new pair of shocks than CRY some more than things should be like they used to
Old Jun 18, 2002 | 06:19 AM
njmaxseltd's Avatar
Re: Re: Hit a huge pot hole, damaged 2 Konig's and blew a shock. What do i do now??
The warranty that came with my AGX's says Lifetime warranty to the original owner as long as the car isn't lower more then 1.5 inches.
Old Jun 18, 2002 | 06:36 AM
Nick97SE's Avatar
Re: Re: Re: Hit a huge pot hole, damaged 2 Konig's and blew a shock. What do i do now??
I was just about to mention this, however perfectmax is running Sprints (2" drop) therefore his warranty is void! I know it sucks, but you're probably gonna have to eat the loss unless you can get the state to pay for it. Anyways, I think Phuong sells the AGXs separately if you need to buy just one.
http://www.eatricezone.com
Later,
-Nick
P.S. If you're gonna go to the state, I suggest you do it fast before they fix the pothole like someone else mentioned in this thread!
Old Jun 18, 2002 | 06:42 AM
StygianMax's Avatar
Re: take pictures and measurments today
brandon
Euro's is right. I work for the provincial road authority in Ontario, Canada & I'd sugggest the same thing. We have a Claims Dep't that handles just this type of claim from the public. What you should do is document all the details to a "tee" (road name, direction you were traveling in, date, time, etc.). Get photos of the pothole (safely!) if you can. No one can dispute photo evidence. Get a zoomed out shot as well so that it's clear where the pothole is located.
It is the responsibility of the road authority to provide a safe driving envirionment to everyone. This is one of the key mandates of my our Ministry of Transportation. I'm sure it's the same where you are. Be prepared for them to dismiss your case initially so you'll have to be persistent.
You should also see who you can cc your letter to (e.g. AAA, local political representative, newspapaper????) That might lend a bit more profile to your claim. No road authority wants to see their name in the news in a negative light.
Good luck!
Old Jun 18, 2002 | 08:01 AM
perfectmax's Avatar
Yes, the sprint drop is probably around a 1.8" drop. Are they definately going to be able to tell that it is under the 1.5" drop that is manditory for the warranty to be valid? Should i send the strut back to them anyway just to push my luck?
Old Jun 18, 2002 | 09:21 AM
_DRU_'s Avatar
i dont see how they could tell whether your car is dropped more than 1.5 inches. there is substantial wear on the struts, but they have no proof that it was because of a drop more than 1.5 inches. could have been extremely poor road quality or possibly a faulty strut. i dont think they will reject your warranty claiming your car was dropped more than 1.5 inches.
litch
123
Jan 4, 2024 07:01 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Marc2theMax
Sep 28, 2015 08:13 AM
