Attention To Those Who Have Done A 5spd Conversion....
if ur reverse light does not work...i think i can help...if u cannot put the stock hydraulic lines for the clutch cylinders i think i can help...i'm doin some experimenting thanx to kaleb at courtesy nissan...so far it's working...and the reverse light for me def works...special thanx to hlh? and cbr? for their write-up...thanx to ericdwong and turbo95max and aznstevie for their help when i had something stoopid to ask...also i think i can trick the ecu to not throw any cel...but i haven't tried yet...for the reverse light it's kinda tricky to try to explain so if ya'll want aim me up and i'll try to explain...
Re: Attention To Those Who Have Done A 5spd Conversion....
This probably won't work but I am going to find the resistance of the sensors on the auto and just put a resistor on the connectors from the ecu.
Re: Re: Attention To Those Who Have Done A 5spd Conversion....
Originally posted by Iron Lung
How do you plan on tricking the ecu?
Re: Re: Re: Attention To Those Who Have Done A 5spd Conversion....
i don't wanna sound stoopid so i'll just go ahead and try it first...if it works then i will post it...if not then i'll keep it to myself...but ur idea isn't bad..but there is a prob...u would have to knoe which two pin of every harness to measure for the impedence...and a couple of harness has more then two wires...
Re: Re: Re: Re: Attention To Those Who Have Done A 5spd Conversion....
true it would take a while to figure out which ones go where, but if I get resistance then i've got the right wires.... unless some sensors have three wires... oh hell i'll just go get a 5 speed computer.
ef9
Oct 4, 2015 08:43 AM
umnitza
Sep 1, 2015 01:03 PM
