Some pics of the Max on Weapon-R coilovers.
Old Jun 19, 2002 | 01:49 AM
Prolepsis's Avatar
You can look at my sig for comparison, let me know what you guys think. The ride is hella stiff with AGXs set to 2 and 4, but I like it that way; takes corners like a race car! Still trying to figure out what to do about the noise when I steer hard.
Old Jun 19, 2002 | 01:52 AM
spiff56747's Avatar
Nice drop man, get some rims, and your car will be very nice looking.
Old Jun 19, 2002 | 06:01 PM
Supa Lao's Avatar
Drop looks good. Let me know how the car rides if you take out the keeper spring in the rears
Old Jun 19, 2002 | 06:41 PM
gtr_rider's Avatar
192.168.1.1
Thats low!
Old Jun 19, 2002 | 07:12 PM
MaxSpeedSE's Avatar
A few questions
Hey thats a nice *** drop....thats how a drop should be.... how much are Weapon R coil overs? Where can you get them?
-ChRi§
Old Jun 19, 2002 | 07:59 PM
SLC I30t's Avatar
Re: A few questions
-ChRi§
that looks to be about 2 inches right? Wouldn't intrax be a better idea? That way you don't have to deal with the weight load on each corner?
Old Jun 19, 2002 | 08:05 PM
MaxSpeedSE's Avatar
Re: Re: A few questions
nah i hurd weapon R coil overs can be lowered up to 4 inches
Old Jun 19, 2002 | 08:07 PM
SLC I30t's Avatar
Re: Re: Re: A few questions
Well I'm sure that you can lower it that far, but how far is that picture lowered? Also, I don't think that there is enough travel in our suspension to be lowered 4 inches. Does anyone know?
Old Jun 19, 2002 | 08:33 PM
thebigsadler's Avatar
Re: Re: Re: Re: A few questions
4.5" drop in the front when all the way down.. i am close here at about 4 or 3.75ish.. and 4 inch drop in the rear.. this is about 3.75 or 3.5.
oh yeah and i have the strut purches cut and rewelded in the front
Old Jun 19, 2002 | 08:41 PM
NickStam's Avatar
damn, that's low, but looks good.
Old Jun 19, 2002 | 09:11 PM
tiedyemaxima
Look Nice man. I like the drop!
Old Jun 20, 2002 | 12:20 AM
Prolepsis's Avatar
Thank for all your compliments!
I'm not really sure how far the drop is. I wish I had measured before I did it, but I was just so excited that it didn't even occur to me. I plan on attempting to take the rear lower, so it's even with the front, but I have to remove the "keeper" coils that soften the ride. Hopefully adjusting the shocks will compensate
I paid $160 for these ones preowned. You should be able to get them new for $250 here:
http://www.importstudio.bigstep.com/
Old Jun 20, 2002 | 08:41 PM
hows the amount of noise and what struts are you on?
Old Jun 20, 2002 | 09:42 PM
mitch33x's Avatar
going to get bigger wheels?
Old Jun 23, 2002 | 11:41 PM
Prolepsis's Avatar
I just removed the keeper (softener) coils in the back to get it a little lower. Apparently, the weight shift made the front end raise up a little bit:
My apologies for the delay answering these questions:
I am on KYB AGX struts.
I hear some crunching/clunking from the front when I steer, but I'm sure there is a way to get rid of it. Before I removed the rear keeper coils, there was no noise going over bumps and such, but now the back is pretty loud.
Bigger wheels are a long way off due to budget constraints and priorities. A y pipe and nitrous are higher on the list.
Old Jun 24, 2002 | 06:29 AM
for the rear noise, did you make sure to retighten the rears when you brought the car down off the jack??
and for the front, i have replaced the strut bearings and used coil wrap and it still clunks, it is the spring pivoting on the sleeve, no real way around it.. maybe coil wrap on the bottom of the threaded sleeve.
btw - i'd suggest jacking your car up once a week and getting a can of wd40 or that air that sprays out of the can to clean the threads in the sleeves, i've had two lock up on because they get any dirt in there and you can't move them.
Old Jun 24, 2002 | 06:45 AM
gtr_rider's Avatar
192.168.1.1
solution: http://www.vqpower.com/noiserem.htm
Old Jun 24, 2002 | 06:48 AM
//M5'ver
if you don't have anything nice to say. don't say it
so um..
Old Jun 24, 2002 | 08:20 AM
Prolepsis's Avatar
The rear is good and tight. I think the noise just happend because the main coils don't have enough travel. The 4" springs are probably already compressed 1.5" from the weight of the car, and maybe another 1.5" is the actual width of the coils (educated guesses), leaves about an inch to move. Try to take a 1.5" bump, and it doesn't do that well (old railroad crossings are especially scary). I may eventually wuss out and put the keepers back in and just live with the higher rear.
Thanks for the advice, much appreciated!
Old Jun 24, 2002 | 12:13 PM
no problem.. i have the rear keepers in.. and i can tuck all of the tire on my 18's.. maybe rims is where you need to be.. like visa.
yeah i hate RR crossings.. worst ever. another thing to consider is putting another one of those thick rubber bushings in the mix somewhere for the rear, i have 2 in there and there isnt much noise from the rear.. but the front is still clunky.
but pretty soon ill be going from a 4.5" drop to a 6.5" drop..
Old Jun 24, 2002 | 03:28 PM
lgsmaximaman
i took all my keepers out one day and it rides like crap, so i put the fronts back in, and every time you go over a bump the car slams down on the i beam in the rear, i can tell this becuase 1) the noise is loud as hell 2) the beam got marks on it......but it looks hella low but too low for new hampshire......
Old Jun 24, 2002 | 05:47 PM
Supa Lao's Avatar
the car looks good w/ the rear matching the front.
captchaos
Mar 15, 2016 12:18 PM
ik95
Sep 16, 2015 08:11 PM
Pixel
Sep 15, 2015 05:53 AM
MaxLife17
Sep 8, 2015 02:36 PM
