Wire harness question
Old Jun 19, 2002 | 05:03 PM
greenmax's Avatar
I just hooked it up like a week ago and went i turn on my lights my dashboard high beam light is on like light not dark.I lost my high beam but went i switch the high beam it dark.What do you guys think could be wrong or is that normal? THANKS FOR ANY INFO
Old Jun 20, 2002 | 07:38 AM
Ravq's Avatar
Sounds like a problem with the harness. Please tell us which brand harness you have. Try disconnecting it and reconnecting the stock harness to see if it's your harness or maybe your bulbs or fuse.
Old Jun 20, 2002 | 06:40 PM
greenmax's Avatar
I got it off ebay and dont know what brand it is i have 100w bulbs and high beam light is only on light and dark went i hit the high beam i will try disconnecting to see if it works.Thanks for the help Ravq
Old Jun 20, 2002 | 06:50 PM
Ravq's Avatar
Keep us posted.
Old Jun 20, 2002 | 07:17 PM
iregula's Avatar
when you connected the harness and matched the colors, it might not be the same wire try differenct combinations
Old Jun 21, 2002 | 04:28 PM
greenmax's Avatar
I try disconnecting and put it back together.Its still the same Its 2 plug to the headlights two for ground and two for battery.Everything seems to be good but the light is still on only went i turn my headlights on.
Old Jun 21, 2002 | 04:35 PM
Ravq's Avatar
What do you mean by "the light is still on only went i turn my headlights on"?
Old Jun 21, 2002 | 04:42 PM
greenmax's Avatar
Went i turn on my headlights my high beam light is on light and dark went i switch to high beam.
Old Jun 21, 2002 | 04:45 PM
Ravq's Avatar
Sounds like some of the wires are switched around. Do your low beams work fine?
Old Jun 21, 2002 | 04:56 PM
greenmax's Avatar
It works fine my low beam but went i look at my dash.Thanks for the help i will contact the seller and see what he says.Thanks for the help
Old Jun 21, 2002 | 05:05 PM
Ravq's Avatar
Compare it to this wiring diagram.
This might also be of assistance. There is a pic of a wiring harness on the site.
http://www.suvlights.com/
You might be able to use a voltmeter or a multimeter to measure the voltage. I suspect something screwy but I'm no electrician.
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
