How can I get the cigarette lighter to always supply power?
Old Jun 22, 2002 | 12:06 PM
97max5spd's Avatar
Is there a simple way to reconfigure the cigarette lighter to supply power even when the car is off?
Old Jun 22, 2002 | 12:44 PM
nadir_s's Avatar
vicodin ... gift of life
Re: How can I get the cigarette lighter to always supply power?
rewire the cigarette lighter directly to the battery... or just connect a wire to ure battery then pull it from the bay to the dash then directly connect it to the cigeratte lighter
Old Jun 22, 2002 | 04:16 PM
97max5spd's Avatar
Is there a relay that controls it? Maybe I can wire the "on" signal of that relay to the battery instead of from the ignition? If I run a wire, do I have to run it all the way to the battery or can I get a hot wire from somewhere inside the car?
Old Jun 22, 2002 | 04:18 PM
nadir_s's Avatar
hot wiring it from inside the car is the best way to go. I would say to use the wire that connects the ignition to the battery... i'm not sure which one it is. If you can't find the wire or whatnot, just pull a new wire from the battery through dash.... good luck
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
