Another VI installed...
Old Jun 22, 2002 | 04:57 PM
Mishmosh's Avatar
Just got my VI today from Japan, courtesy of Mr Cranman's deal (THANKS JOHN! ).
It arrived very well packaged with most items in sealed NISSAN packaging. Everything brand spanking new. All parts were included with the exception of the brake boost vacuum port which I unscrewed off of my other intake manifold. Package was shipped 6/19 and today is 6/22!!! Invoice included. Total package TOP NOTCH, very impressive...
Install was pretty straight forward. Took me about 3 1/2 hours but that doesn't included the Harlan RPM setup that I did earlier. Toughest part was the two bolts in holding the manifold down in back and the two coolant hoses in back--you think the fuel filter change was tough, these two were damn nasty! Anyways, mounted the NAPA vacuum canister in front of the VI where it will be covered. Everything fit perfectly and none of the bolts were difficult to remove. Harlan RPM (in gear box area) ran off coil pack #1 and activates Dawes Devices control solenoid.
Here is a pic with everything but the cover installed:
And one with the complete thing done!
Test drive: very brief but I was easily able to appreciate the pickup after 5k rpm (VI set pt)--it was AWESOME!!! Very similar to the zoom you get from 3k-5k but it just goes all the way to redline instead of going limp... Install was done by me alone so anyone can do it!
Thanks again to Mr Cranman and also props to those who contributed to making the VI a reality Stateside (MardiGrasMax, IanS, in particular)--your efforts are all very much appreciated.
I have a bunch of pics if anyone has something they want to see... I may put up some install pics/tips later. Also, get the damned cover! It hides your vacuum stuff AND also the nasty OEM harness in front! Looks better than before wouldn't you say?
*Highly recommended mod*
Old Jun 22, 2002 | 05:21 PM
Confused's Avatar
Permanent Maxima.org Resident
Congrats~!
Old Jun 22, 2002 | 05:43 PM
Kevin Wong's Avatar
Cool
I'd really like to do this mod, but I'd like to see more power gains down low and the set point lowered to 4,250 or so. I don't know the whole mechanics nor what is optimal, but I just wish to see more useable power gains.
Well, as long as I'm thinking about it, I wish Nissan would have made the 5th gear taller and the final drive a little shorter, too. I think the Maxima's tranny is not to the engine's potential.
Old Jun 22, 2002 | 06:06 PM
NotNew!!NewSN!!'s Avatar
my god do i want that, and that cover has that new 2002 style to it, how much was it from cran man again????
Old Jun 22, 2002 | 06:27 PM
Mishmosh's Avatar
Here's another pic with the stock manifold out. Rear harness pulled left, out of the way. Throttle body and CAI left undisturbed. TB, IAC, EGR guide tube gaskets looked fine and were reused. Stock bolts were likewise fine and reused. I had measured manifold vacuum some months ago and it was 21 inHg at idle. After install today, it was 20 inHg (still in normal range).
BTW, when I connected two Harlans to the TAM screw in the guage cluster, I experienced a similar phenomenon that xHypex reported earlier--that is, the tachometer just goes dead. I now have one harlan working off the TAM (shiftlight) and the other (VI rpm switch) working of coil pack #1 (wht/red lead).
Old Jun 22, 2002 | 06:34 PM
Iron Lung's Avatar
Re: Another VI installed...
Are you going to stick to the CAI or do you think you'll go with a hybrid?
Thanks for posting this. I can hardly wait to get mine.
Old Jun 22, 2002 | 07:05 PM
BBaker025's Avatar
Next thing to do is get your engine cleaned . Id be embarased to show off my VI with that dirty engine....j\k Good job with the install, I hope to get one when I get the funds!
Old Jun 22, 2002 | 07:15 PM
Mishmosh's Avatar
Heh heh... yeah it's pretty dirty. Never have been one for keeping the engine bay all shiny clean. At least the new VI and cover give it a little pizzazz...
Re: CAI. yeah, I'll probably keep it, even though I've thought about hybrid intake. If I lose a little up top, then so be it. I love the CAI and besides, I went through a lot of trouble getting that hole in the fender wall, dammit!!!
Old Jun 22, 2002 | 07:29 PM
redmaxpa007's Avatar
i SeE what you did therE
looks good..!!
congrats..
new buy me one and install it for me..
Old Jun 22, 2002 | 08:05 PM
Mishmosh's Avatar
3 more pics.
Pic showing where I t-pieced into the vacuum line going to the fuel pressure regulator which is right in the area. I used 3/16" tubing in some parts but mainly, one I.D. smaller (sorry, forget the actual #) worked best for most of the vacuum hose.
The NAPA vacuum canister, which has a built-in one way check valve, is fed manifold vacuum. It then feeds the control solenoid which opens when the Harlan RPM switch is activated.
Lastly, just wanted to clarify what I meant when I mentioned that I reused the brake boost vacuum port. Just unscrew it off your stock manifold and screw it in the hole circled in black.
Some install tips:
-consider Li grease in appropriate places on the rod that holds the butterfly valves ie. where it rotates inside the manifold. It may be smooth now, but the parts are brand new!
-consider silicone adhesive or thread lock on the screws that hold the butterfly valves in. You can ill-afford these things to make their way loose.
-try using a small 1/4" socket wrench with a 12mm socket for the back manifold bolts and also the EGR guide tube bolts. Space is tight back there.
-be careful when taking out the EGR guide tube bolts. The metal gasket drops down easily and the bolts have fat washers that can also fall down, never to be found in the engine bay.
-the above crap falls down into your engine bay and so do other sockets, tools, bolts, etc---make sure you have a good magnet antenna.
-when installing the new VI, line up the upper-to-lower manifold gasket first, then mount the new VI, aligning the VI ports, but only loosely tighten the left and right bolts just enough to keep the ports in correct position over the gasket. You will need to thread the two rear manifold retention bolts before you tighten all the front bolts.
-a relay used between the Harlan and the solenoid will effectively convert a switched ground into a switched 12V activation line. The ground for the solenoid can be had from one of two grounding screws located in front of the VI (will be covered up by the VI cover).
-it may be helpful to remove the black cylinder that the cruise control cable is attached to (held in by two 10mm bolts to the firewall), to give yourself some room back there allow easy manifold installation.
Old Jun 22, 2002 | 08:10 PM
Mishmosh's Avatar
Better yet, you can have mine! We can just exchange cars...
Old Jun 22, 2002 | 08:20 PM
iansw's Avatar
Yes, those rear clamp bolts are a PIA, aren't they...?
Good job, and that cover looks great! My supplier is unable to get them, so I will be ordering one from Cranman VERY soon.
IanS
Old Jun 22, 2002 | 08:52 PM
aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
NO
Old Jun 22, 2002 | 10:32 PM
XXXL Cracker's Avatar
Also got a present today
Received my VI today also. Will not be installing for a few weeks. I am a little nervous about the install. Is there a write up or how to?
DL
Old Jun 23, 2002 | 02:06 AM
xHypex's Avatar
Glad to see everything worked out, and thanks for the pictures If you want I can add your pictures/thoughts to my page for the VI and maybe we can get a decent how-to going. I should be helping Murphy_TX_Mike install his VI next week, and my VI should be here in about ~4 weeks (I opted for sea freight with Keven97SE ).
-hype
Old Jun 23, 2002 | 06:42 AM
dirtsmax's Avatar
What did it cost?
All said and done, what was the total cost of the project?
Also can Cranman get these things whenever he wants? I mean do we have to wiat for a group deal or can I order one whenever I have the funds?
Old Jun 23, 2002 | 08:25 AM
speedtrip's Avatar
Nice Job! The variable intake manifold really finishes off the VQ for us 4th gens.
I will probably be adding a shift ligh soon and I have a question about how you wired the rpm switch to the TAM screw. Did you try to run two tach input wires off of the TAM screw? Or did you try to splice the tach input wire for the rpm switch into the tach input wire for the shift light so only one wire would be connected to the TAM screw?
Thanks!
P.S. when's the dyno!?!?!?!?
Old Jun 23, 2002 | 08:29 AM
Mishmosh's Avatar
Re: What did it cost?
I think a complete install will run you about $600-700. The variability comes mainly from how you get it shipped, whether or not you opt for the cover, how cheaply you get parts for the RPM vacuum switch subsystem. My total cost was probably around $700.
IanSW has a GD in progress sourcing from the Middle East. Cost is similar to Mr Cranman's deal with sourcing from Japan. Mr Cranman has the advantages of the cover option ($50 extra, but well worth it), two shipping options, and convenience of ordering any time. Fulfilment times: Cranman ~6-8 weeks (6 1/2 weeks for me), IanSW ~8-12weeks (maybe less). Both are honest joes. I can say about Mr Cranman's source that the business is very thorough in packaging, completeness, and shipping (including customs handling)--I think their specialty is exporting Japanese auto parts internationally. Payment options for both are less than ideal (ie. no credit card) but acceptable/understandable.
Old Jun 23, 2002 | 10:05 AM
Dave B's Avatar
Not DAVEB the parts guy
No group deal needed under Cranman's VI deal. The only hang up is the limited availability of these manifolds. They're probably having to make them to keep up with the demand.
Everyone else-
Did Cranman send you a tracking number or anything or did the package just show up? I should be getting mine soon. I hope. I ordered on the 5/20.
Dave
Old Jun 23, 2002 | 11:32 AM
John sent a tracking number
Cranman was exttemely helpful in coordinating things with his contact..
Sent me an email with the tracking info!
DL
Old Jun 23, 2002 | 12:22 PM
Mishmosh's Avatar
Re: Re: What did it cost?
Originally posted by Dave B
Everyone else-
Dave
Actally, a pic of the actual shipping paper was emailed to me by Mr Cranman. You then can track on the EMS site although their status is not very up-to-date--I'd say more like 24hr behind. Because it lists when the flight your package will be on leaves, you kind of can figure out when it will ship out.
My BAD: I actually ordered 5/9/02, so it actually took 6 1/2 weeks or so to get in my hands. Don't worry Dave, I'm sure yours will be ready soon. I know given the RB fiasco that all of us are a little worried....
Old Jun 23, 2002 | 12:31 PM
Mishmosh's Avatar
My first Harlan (shiftlight) was connected of the TAM screw in the guage cluster. When I went to connect the second Harlan up to the same line, the tach needle just died. This was implemented by a single wire connected to the TAM screw, running down to the gearbox where I hooked up both the inputs of the Harlan. Either one run singly off this wire was fine. I then just hooked it (Harlan#2) up to coil pack #1 via a wire through the firewall.
Old Jun 23, 2002 | 01:45 PM
dwapenyi's Avatar
Nice job. MishMosh. Great PICs. Dyno that sucker!!
I am also eagerlay awaiting mine.
DW
Old Jun 23, 2002 | 05:00 PM
BSwithTF's Avatar
I throw in my thoughts here as well.
Packaging was great. Looked like I went down to Nissan and picked up all the parts myself. Updates were very good from Cranman. He always gave any info he had on when it was going to be shipped and all that. I haven't had the time to get the whole vacuum system up and running but I can say, with this thing tied open and flooring it, it straight gets up and scoots! Very worthwhile mod, both in time and money! Thanks John!
Now if I can get some track time and dyno time squeezed in here somewhere!
Old Jun 23, 2002 | 06:16 PM
RS Motorsports's Avatar
Re: I throw in my thoughts here as well.
Ya i must say that cranman is the man, I just got my VI today and the packaging was great, I so want to put it on right now but i don't have all the parts i need aww the wait is gonna kill me.
Ryan
Old Jun 23, 2002 | 07:01 PM
Write up for vaccuum
I was wondering if anyone could help with a write up for wiring up the RPM switch, vacuum solenoid etc.
I am a little in the dark and need some help.
Thanks in advance!
DL
P.S. The only write up I saw was on Iansw's page.
Old Jun 23, 2002 | 07:53 PM
xHypex's Avatar
I made a parts write-up a long time ago similiar to Ian's.
http://www.vanillaice.com/webmasters/hype/mrc/mevi.htm
Tonight I added a how-to section with help from the very meticilous Mishmosh
http://www.vanillaice.com/webmasters/hype/mrc/mevi2.htm
Hope that helps.
-hype
Old Jun 23, 2002 | 09:04 PM
96BLUMAX's Avatar
Looks cool. Does this mod mess with emissions at all?
Old Jun 24, 2002 | 08:22 AM
Mr Cranman's Avatar
All said and done your looking at probably around $625 or so. I can order them whenever you feel like ordering one...the only thing is it takes about 4 weeks for my supplier to get them in and then he has to ship it to you. The other problem is the price might vary depending on the currency exchange rate. Because when I first bought mine the US $1 was worth $130 yen...when I did the deal it was only worth $125 yen, and currently it is like 123.5 yen. So, that can change the price by approximately 5-20 dollars. Just to be forewarned. But, when your interested just let me know and I'll be more than glad to get the ball rolling.
-John
Old Jun 24, 2002 | 08:29 AM
Mr Cranman's Avatar
Looks awesome!!!
I think I might have to buy the cover now. Looks great...can't wait to see some quarter mile times. I need to make a trip to the track like a 4 hour trip (that is how far it is to a 1/4 track and back).
-John
Old Jun 24, 2002 | 10:33 AM
97GLE's Avatar
Yeah, has anyone gotten thier car inspected yet?
Old Jun 24, 2002 | 10:46 AM
Mr Cranman's Avatar
I don't know of anyone.
But, I don't understand why it would effect emissions. I mean they have these on cars over in Britian and there emission test are a lot more strict then ours hear in the states. If anything this probalby helps your car run more efficient!!!
-John
Old Jun 24, 2002 | 11:13 AM
97GLE's Avatar
Re: I don't know of anyone.
-John
Understood, I didn't realize they were on European cars. I thought they were from countries that didn't have very strict emissions. Now I don't understand why this wasnt on our cars to begin with.
Old Jun 24, 2002 | 11:27 AM
Dave B's Avatar
Why wasn't this on our cars to begin with? Probably because Nissan didn't want a sedan being faster than their NA 300ZX and within .8 seconds of their 300ZXTT.
Dave
Old Jun 24, 2002 | 11:34 AM
RAZER's Avatar
How much $ and where can i get one???
Old Jun 24, 2002 | 11:50 AM
iansw's Avatar
This hsould not affect emmissions whatsoever.
When I get my Emissions test, I'm just going to disconnect the RPM switch from the relay anyway, then I'm pretty much the same as stock. I think they'll worry about my SC alot more anyway.
I used to sell them, and will probably be doing another Group Deal later this year. $560, plus you need to purchase the RPM Switch and vacuum system yourself.
www.cyberhub.net/intake
IanS
Old Jun 24, 2002 | 11:55 AM
speedtrip's Avatar
Re: Re: I don't know of anyone.
I don't think the VI was available until 1997. I would guess the reason why the US didn't get it then or later is marketing. In our market the VQ already had the accord and camry V6 beat in performance. A late model 4th gen with VI would have taken some of the punch away of the 5th gen hp increase as well. Also Nissan wasn't in good finacial shape and they weren't making the best of decisions back then either.
Old Jun 24, 2002 | 11:56 AM
iansw's Avatar
Actually, according to Nissan's Middle East repot for 1998, it was released then. So you could say mid-1997, as that's when the 1998 models came out.
But it's on the 1998's, not the 1997's.
IanS
Old Jun 24, 2002 | 12:09 PM
dirtsmax's Avatar
John,
Thanks!! It is great to be able to get this thing whenever I have the funds which could be a while. BUt I really want this thing! I don't race my car but I like having the power when I want it. I have a couple of other things to do before this mod. THanks again!
-John
Old Jun 24, 2002 | 12:10 PM
Mr Cranman's Avatar
About $520
Don't have to wait for a group deal to buy from me. Just when your ready tell me and I will put in an order for you. It takes about 4-7 weeks to get it from the time that you send me your money. If you have any questions just shoot me an email and I'll be glad to answer any of your question and if your looking at buying the cover it is an additional $70
-John
