Question about adding RESTORE engine restorer & lubricant
Old Jun 22, 2002 | 07:40 PM
MaxC1Get!'s Avatar
I'd like to know if anybody has added RESTORE engine restorer to their oil. Is it a safe product to use for the VQ, and have you noticed any difference with your engine?
Thanks,
Don
Old Jun 22, 2002 | 07:42 PM
mzmtg's Avatar
Minister of Silly Walks
In high school, my friend put it in his 85 Crown Vic. According to our stopwatch, it dropped the 0-60 time from 20 sec to 15...
Old Jun 23, 2002 | 09:02 AM
iwannabmw's Avatar
How long did the crown vic last after??
Old Jun 23, 2002 | 09:08 AM
GreenMaxVE's Avatar
Re: Question about adding RESTORE engine restorer & lubricant
I added it to my old car. A 1980 Mazda GLC. I noticed a little increase of power, but the car only had 52 HP to begin with so it wasn't a big increase.
Old Dec 3, 2002 | 06:25 PM
jkmay01's Avatar
Lil 8
Re: Re: Question about adding RESTORE engine restorer & lubricant
Has anyone added it to a VG engine in the 3rd gen max? will it cause any problems with full synthetic oils? benefits??
Old Dec 3, 2002 | 06:40 PM
MaxEffect414's Avatar
I have used this in my 99 Max cause i have aboout 99K miles and i noticed a difference in power, It wasn't all that but i did notice something which means you will notice something which means it did it's job.
I will add again when i do oil change.
I also noticed no problems....
Trance.....
Old Dec 3, 2002 | 07:42 PM
Eric L.'s Avatar
Restore is one of those miracle in a can fix-it cures for low compression. Cartalk (Tom and Ray) tell their callers to use it as a last resort before a ring job on the engine. I would not add those little metal particles in the restore unless I had a low compression reading after an engine diagnosis.
Old Dec 3, 2002 | 08:47 PM
KFL's Avatar
KFL
I would have to agree with Eric L on this point. No point in using it unless the engine has high mileage and compression test indicates abnormal numbers in a cylinder. My friend uses Lucas oil stabilizer it actually did feel a bit different.
Old Dec 3, 2002 | 08:51 PM
Nismo's Avatar
Old Oct 26, 2003 | 09:04 PM
6re99's Avatar
i ibought a 15.fl can today to throw in my next change.. . im running engine gUnK for 3-7 first .. let it roll and then slide on outh....
them on putting in a fram
i had a 2d Generation Fireball on my accourd.. and i wonding if it wouldless enough hassl to go run to the csrap [;ece ehe as my care and try to jax saw my muffler..
anyway.. this car kicks *** to be so o.d.
Old Oct 26, 2003 | 09:37 PM
ivelweyz
You're supposed to use that a few times for it to work. Using it once won't do ****. Use it for like 2 or 3 oil changes and it should help...
Old Oct 26, 2003 | 10:23 PM
NOMAD MAXIMA's Avatar
I've used it twice together w/ sythetic oil only because of my high milage
and my upcoming performance mods. I guess kind of an extra protection.
lowpost99
Oct 20, 2015 07:42 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
09maxshawn11
Aug 9, 2015 01:13 PM
