How difficult to replace clutch?
Old Jun 23, 2002 | 08:24 AM
PRPmax's Avatar
My clutch has been slipping for some time now. I just recieved my ACT clutch yesterday. I had gone around getting some prices on installs. I've gotten price ranging from $350-500.... I really don't have that much laying around it'll take me like a month to save up for this, but I know it needs to be replaced soon. I have tons of tools to do this myself. I was reading through the haynes repair manual, and it doesn't seem that difficult. Just looks like it'll take a good weekend.
For the guys that have done this themselves, How long did it take you also what problems did you run into installing ?
Thanks,
Nell
Old Jun 23, 2002 | 10:10 AM
Yellowbrother's Avatar
changing the clutch is practically 90% of the process to change an auto to a manual...u have to take off front wheels...take off both driveshaft...take off intake and battery cuz they will be in the way...take off tranny...take off clutch...replace clutch...put tranny back (this step alone can range from 30 min to 3 hours)...put drive shaft back on...put wheels back on...put intake and battery back on...bleed the clutch...ur done...
Old Jun 23, 2002 | 11:59 AM
iwannabmw's Avatar
By far, the most frustrating part was putting the tranny back on.
Old Jun 23, 2002 | 10:03 PM
PRPmax's Avatar
Sooooooooooooo..... you guys are saying I would be better off paying someone to do this?
Old Jun 23, 2002 | 11:05 PM
SuDZ's Avatar
It is pretty basic in thoery. Mainly give yourself plenty of time and dont rush it. It is all piece by piece as you go but see if you can get a few people to help you. It will come in handy on some parts.
SuDZ
Old Jun 23, 2002 | 11:39 PM
tvn_1010's Avatar
Re: How difficult to replace clutch?
Thanks,
Nell
How do you know your clutch is slipping? I have been driving 5spd for quite sometime now and never know what "slipping" really is.
Old Jun 24, 2002 | 04:51 AM
hlh0501's Avatar
you do not have to bleed the clutch lines for a clutch change, the slave cylinder unbolts from the transmission with two bolts, and is a closed system, no fluid gets out.
it is about 70% of the swap, b/c doing the clutch lines was a pain in conversion.
do it youself, I just changed my clutch,flywheel, and transmission (to vlsd 5spd) a couple weeks ago... did it in one night. I have more pics if they would help at all but probably not, its nothing craaazy hard, just time consuming, if its your first time, plan it taking a whole day, or maybe two
best of luck, !!
Old Jun 24, 2002 | 05:17 AM
best of luck, !!
for me it was 90% of the swap cuz i did something else with the clutch lines cuz the oem twisted and turn too much...
Old Jun 24, 2002 | 09:25 AM
PRPmax's Avatar
tvn_1010: I know its slipping cause when I shift into 3rd,4th,5th. Punch the gas. It take a second for my clutch to engage. My RPM's will rise then fall back to were there suppost to be at.
hlh0501: Yeah this is my first time replacing a clutch on a FWD car. All my previous cars were RWD. Changing them out looks to be a lot easier. I'm really wanting to do this myself. I have a spare car, so if it takes longer then I expect. I won't be stranded. I just need to clean out the garage so I have some room to play.
The manual I have don't make it look so hard mainly due to all the pics. Gotta love Haynes!!
Old Jun 24, 2002 | 09:32 AM
dgeesaman's Avatar
Maintenance Monster
Check out the procedure on www.motorvate.ca and search the archives for others on the web.
Dave
Old Jun 24, 2002 | 09:33 AM
blizz20oma's Avatar
I'm so hood
If you have an extra ride, I say clean out the garage and go for it. That is, if you have the tools and an extra body or two. Maybe by the time I replace my clutch I'll have enough tools and knowhow to undertake the task myself....with the trusty haynes by your side, why not?
You sure your clutch isn't just chattering a bit / you're gassing a bit too much on the shifts? I always thought the clutch slippage test was to have it in 5th at about 40mph or so (foot totally off the clutch), to get it low into the powerband...floor the gas, and then if the RPMs spin up without speed picking up, thats slippage. I think that test is even DBM-approved.
Old Jun 24, 2002 | 02:13 PM
PRPmax's Avatar
I'm pretty sure its on its way out the door. I really don't shift hard at all. When I'm in lets say 4th, i'd be doing about 60-65mph. I'm at like 3000rpm, So I don't shift and just push on the gas and my rpm will just rise then come back down, THEN my clutch will engage. I checked out all the other possiblities. It has to be my clutch. I got my weekend project now.( Clean out the garage ) So much crap in there.
Old Jun 24, 2002 | 03:21 PM
ejj's Avatar
ejj
Yup, that's the tell tale sign that a clutch is slipping. Take lots of pictures!
Old Jun 24, 2002 | 09:16 PM
hlh0501's Avatar
i just swapped my car from 5spd to lsd 5spd, and have tons of pics if you need/want..
Old Jun 24, 2002 | 09:29 PM
PRPmax's Avatar
How did you do that? Was it any more difficult?
Yeah pics would be nice. Email them to me (Nelson_Burgos@yahoo.com) or IM me NBpico00.
Old Jun 24, 2002 | 10:28 PM
Altimat's Avatar
ActiveTuning Partner
The difference between the 30 min. and the 3 hours is how well you aligned the disc with the clutch alignment tool when you installed the new clutch.
Old Jun 25, 2002 | 04:43 AM
hlh0501's Avatar
It is a whole transmission, so no it was not difficult - time consuming just to take the old one off (i also swapped the flywheel - so the clutch and everything came off too), but its just bolting up a new tranny... i will have pics for you in a day or so... email me if i forget.
Old Jun 25, 2002 | 11:35 AM
PRPmax's Avatar
How much did all that run you ?
CorollaULEV
30
Aug 9, 2021 08:11 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
vanebecker
Aug 17, 2015 08:24 PM
