Ultra-Efficient AC Hydrocarbon Refrigerant
Old Jun 29, 2002 | 08:26 PM
karguy's Avatar
Have any of you done any research or used AC products by Enviro-Safe? This product (ES-12a) is supposed to be 32% more efficient than R12 and even more efficient than R-134a. It seems the EPA gods made us use a less efficient refrigerant (R-134a) in the name of global warming. By using a more efficient refrigerant in our older AC systems we can recover some of the efficiency we have lost.
Link to their site: www.autocool-refrigerants.com/product.htm
A case of 12 cans is $69.00 + HAZMAT Charge (Includes Shipping).
They will give quantity discounts. Is this something we would want to pursue a Group Deal on? I believe the price drops to approximately $30.00 per case of 12 cans in quantities of 100 cases.
Your thoughts & ideas.
Be well!!!!
Old Jun 29, 2002 | 08:43 PM
Eric L.'s Avatar
All 4th gens use R134a refridgerant. Can you even put R12 (or R12a) in the system?
Old Jun 29, 2002 | 09:10 PM
rmb's Avatar
rmb
No....
Good old freon required different pressures which resulted in different seals/lines, etc....
-RMB
Old Jun 29, 2002 | 09:49 PM
karguy's Avatar
The ES 12a is compatible with R 134A and can be used in R 134a systems.
Old Jun 30, 2002 | 09:18 AM
pocketrocket's Avatar
Re: Ultra-Efficient AC Hydrocarbon Refrigerant
Actually, R12 was breaking down the ozone layer. R134a doesn't have the same ozone-robbing effects BUT it does contribute to the greenhouse effect, hence R134a is actually causing global warming ... we just don't get cancer-baked, that's all.
Even though is is compatible with R134a systems, the question is will shops work on your car if they know you have a refrigerant blend? Chances are, a refrigerant ID machine will point out it's not R134a so A/C shops will not hook up their machines to your car because they don't want to contamintae the pure R134a that they have in their tank. A point to consider - check with your A/C shop and see what they say.
dr3am
25
Oct 22, 2015 08:53 PM
SilverMax_04
Fluids and Lubricants
47
Apr 19, 2006 07:36 PM
Scruit
Aug 18, 2005 06:25 PM
Bags
May 28, 2005 08:24 PM
