finally changed out the knock
i cant really feel a difference, YET....im hoping to feel it soon.....it took us a few hours....we tried getting the bolt off, and we actually loosened it, but it was too damn hot down there, so we had gone to get some food, and started working on it when we got back....little did we know that it was actually already loose....we loosened it some more, and got the bolt off.....boy was that the easy part.....none of us (4 guys) really didnt have small hands so it was a real ***** trying to get it back in.....97maximaSE's cousin lived across the street and we called her over.....she got it in within 5 minutes.....i reset the ECU (or so i thought), and took a spin around the block....came back, checked the ECU.....0304... .....i resetted the ECU again, this time i read the directions on the site again, and successfuly reset it.....i let 97maximase drive it because he felt is car felt sluggish on the low end w/ his i/y/e .....he said mine actually ahd more low end (hybrid intake).....well he was taking curves at like 60, and i was shiiting my pants...i thought we were going to slam into every tree...he was used to his RSB max, while mine completely stock suspension wise (save the FSTB), wasnt handling the curves that great.....well now that this problem is fixed, the y pipe is coming in 2 weeks (or atleast im going to order it) and the RSB is a must now that i have felt how it really feels.....when we came back to his house, we checked the ECU again.....0505 .....very happy
well just one question now.....how long after are you suppose to feel the affects of a working knock sensor? also, does your gas mileage come back right away, or what? how does that work? TIA
Re: finally changed out the knock
After replacing the KS and resetting, you should feel the difference immediately. Just has a increased effortlessness when accelerating... I think though that you really have to know your car to appreciate the difference but it is not unlike Y-pipe gains in extent.
How does one tell that their KS is working, but has retarded the timing?
A Nissan Tech told me it won't throw any codes at all, even when checking it manually, if that's the case.
Is that true?
IanS
Is that true?
IanS
Is that true?
IanS
Is that true?
IanS
My mechanic explained to me that there is no quick way to know that timing is being retarded by the KS, because it throws no codes unless the KS itself is bad, or something in conjunction with it....although I had my MAF unplugged and it threw a code a few days ago, it did not throw a KS code.
He was thinking that may be why my boost is low, my timing is retarded because of the KS, but there's no apparent quick way to tell. he wanted to charge me $75.00 to "run a diagnostic" on it.
So can anyone tell me a way to know?
IanS
IanS
i didnt buy em, steve's uncle had em, so we got them, and we borrowed his daughter to thread the nut back into the ks....hehe....i havent felt it yet, i dont think...steve did say my low end was alot peppier than his car (cai, y, b)...and gas mileage...where have u gone ???
IanS
IanS
Anyone want to answer this? How can one tell that the timing is being retarded by the KS when the KS is good. It does not throw a code.
Dave
Originally posted by Dave Holmes
If the knock sensor is bad, it will show a code (03 04) by itsself. It will not trip the Check Engine Light. You have to check the ECU for it. My '96 GXE (RIP) had only a knock sensor code before she bit it.
Dave
Dave
Sorry, it's morning, I'm grumpy, and it's a pet peeve of mine when people don't really read a question asked and then answer.
My question was:
When the KS is WORKING, how do you know if it has retarded your timing?
I think Keener mostly answered it (thanks), anyone know a quick way to check?
Thanks,
IanS
That in no way answers my question. The KS, WHEN WORKING, does not throw a code, even when manually putting the ECU into diagnostics mode. But can retard your timing for whatever reason.
My question was:
Thanks,
IanS
My question was:
Thanks,
IanS
Originally posted by keener
Ian, talked with Nissan and they said the advancement of the timing only occurs when the KS senses the knock...then after the knock disappears the timing goes back to normal. They also mentioned that using a Timing gun under normal conditions (i.e. manually throttling the gas) is not rigorous enough, therefore, the car must be on a dyno. Even on a dyno, they felt the KS may not trip. They suggested checking the ECU for the KS code, if it was there, change the KS and run higher octane gas.
Whenever I went WOT, it made a rattling noise in there. I was wondering if that was possibly causing the timing to be retarded and therefor causing my lack of boost.
But it looks like that's not it, as the screw fell out of where it was stuck somewhere about 2 months ago.
IanS
The reason I ask is that I dropped a screw down in the space on my plenums while changing my plugs a few months ago. While it wasn't anywhere it could do damage, it was impossible to get to.
IanS
IanS
03-12-2020 12:06 AM
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
