I just talked to Eibach technical support
Old Jul 1, 2002 | 09:17 AM
speedemn's Avatar
I had initially called to ask about their Eibach Pro kit vs the springs that they make to go along with the Ground Control coilovers. They said that they make an entirely different spring for the GC coilovers.
Then the guy on the phone said that the Eibach Sportline springs would be better than the Pro kit if I want better launches and a stiffer ride. He said that the Pro kit is more for everyday drivers who want stiffer than stock suspension, but still comfortable enough.
About the GC coilovers he said that it is good in the sense that you can adjust each corner individually to suit your needs (eg if you were on an oval track) but in everyday drivability it can get annoying because it isn't as perfect a fit as the regular springs are.
So I wanted to ask you guys about your experience with the Pro kit vs Sportline kit vs GC coilovers. If performance is my main concern, which would be my best bet? I hate the wheelspin that I get launching off the line (not complaining about it because I'm glad Maximas have that much power) but I'd like to be able to get firmer launches. Then, that taken care of, is the stiffer Sportline kit ride a bad thing compared to the Pro kit?
Thanks for your input.
Old Jul 1, 2002 | 12:59 PM
guido_sst's Avatar
They don't even make Sportline springs for the Maxima, so that pretty much solves your problem right there.
Old Jul 1, 2002 | 01:43 PM
speedemn's Avatar
Oh I didn't even realize that. I thought I saw a Sportline application for our cars on some site a while back... I think I mistook it for something else.
In any case, then what would be a better choice between the Pro kit or the GC coilovers, if what I am after is performance. Is the performance of the coilovers any better than the Pro kit to make it worthwhile to deal with the problems that the coilovers can bring?
Old Jul 1, 2002 | 01:47 PM
jasonz
gc's
if you dont need to adjust your height i would get the spring set
save a few beens for better mods
ps, dont forget the camber factor
Old Jul 1, 2002 | 02:05 PM
speedemn's Avatar
Re: gc's
I don't mind spending a little extra, if I do get better performance out of the GC coilovers as opposed to the Eibach Pro kit.
As for caster/camber, do I have to worry about that with coilovers or is it all automatically adjustable (I am not familiar with coilovers and how they work)? Do I have to buy a caster/camber correction kit in addition to the GC coilover kit??
Old Jul 1, 2002 | 02:30 PM
Nealoc187's Avatar
SLOW
Yes, you do have to worry about camber issues with GC coilovers. Camber plates $$$$ or simple camber bolts can solve your camber problems.
Old Jul 2, 2002 | 09:17 AM
got rice?'s Avatar
GC uses the Eibach Race Springs on their setup - linear rated and much shorter than the Pro Kit setup. You want softer rear suspension to lessen wheelhop on the line. Using the race springs wouldn't be the best option.
Old Jul 2, 2002 | 09:38 AM
NotNew!!NewSN!!'s Avatar
im not disagreeing with you, cuz u def know more about this stuff then me, but u can get softer spring rates from ground control if u buy them directly, in incriments if 50 lbs/inch i think. even if u went down to 250 lb/inch for the rear, it wouldnt be comfy enuff? im not telling, im askin.
Old Jul 2, 2002 | 11:16 AM
Nealoc187's Avatar
SLOW
According to GC, the reason they used such stiff rates as they did is because with anything less the car bottoms out too easily. Since they use such short springs, high stiffness is needed to keep the car from being on the bumpstops at every dip in the road.
Old Jul 3, 2002 | 09:12 AM
speedemn's Avatar
So are you guys saying that I should buy a custom set of GC coilovers and not just a generic GC coilover kit for my Maxima?
As for coilovers themselves, the guy on the phone from Eibach mentioned something about rattling issues from the coilovers since they are not exact fit like springs are. Have any of you guys with coilovers experienced such issues?
Old Jul 3, 2002 | 10:40 AM
got rice?'s Avatar
yes, you can specify *whatever* spring rate you want when ordering them initially (or buying different spring rates at a later date) but since the spring itself is MUCH shorter than the Eibach or stock springs, you do not have as much suspension travel, thus, a stiffer spring is almost a must (or you'll be on the bumpstops constantly).
If people want a soft silky smooth ride, they're barking up the wrong tree here.
Old Jul 3, 2002 | 04:44 PM
speedemn's Avatar
I was looking to buy the GC coilover kit from one of the members on the org. Would I be better off spending the extra money to get it retail from GC so that I can specify all the spring rates?
I know that GC has different part numbers for their coilover kits, depending on the strut that you choose to use - KYB, Tokico, Koni. Would specifying my strut type be sufficient to picking a GC coilover kit?
Old Jul 5, 2002 | 09:30 AM
got rice?'s Avatar
ask what spring rate setup the used kit is. if it's the default setup you should be fine. most people don't need to mess around with different spring rates
Old Jul 5, 2002 | 09:35 AM
Dave B's Avatar
Not DAVEB the parts guy
You're sorely mistaken if you think spring/coilovers will reduce a lot of the wheel spin. If you want better launches, get better tires.
Dave
Old Jul 5, 2002 | 09:38 AM
got rice?'s Avatar
I've had a few customers hook up better after replacing their stock setup (reduction of 60' by .1-.2 sec)
Old Jul 5, 2002 | 11:19 AM
tmkforever's Avatar
Re: I just talked to Eibach technical support
I just installed Eibach Pro Kit springs along with Koni sport shocks all around and I have been very pleased with their performance. They are much quicker than the stock SE struts and springs and I am able to take turns real fast without any drama, lest a little tire squeal in extreme conditions. I really like the 1.5"/1.3" lowering, too.
-Jon
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Peter Paul
Jan 2, 2016 05:18 PM
Turbonut
46
Oct 21, 2015 08:28 PM
