ECU Test
Old Jul 2, 2002 | 10:03 PM
|\|issan|\/|ax's Avatar
ECU Test
I ran an ECU test on my 1995 Nissan Maxima because the Check Engine Light(CEL) was on. I am up with the codes for my problems:
1. EGR System Hi/Lo Flow
2. Intake Air temperature Sensor
3. Knock Sensor
What does each system do?
EGR
Intake air temp. sensor
Knock sensor
How much does it cost, roughly, to replace each?
Do these systems affect performace? I am wondering because I raced a 1989 Acura Legend with more weight, less HP, and less ft. lbs. of torque and lost!! Ahhhhh
One last thing how do I know if my O2 Sensor is shot??
Thx!
Old Jul 2, 2002 | 10:23 PM
munji's Avatar
Re: ECU Test
1.EGR= exhaust gas recirculation, EGR valve checks and regulates the amount of exhaust/gas mixture and puts some exhaust gases back into the intake manifold to dilute the mixture if need be to reduce combustion temp-this could also be from clogging
2.kinda self explanatory
3.knock sensor adjusts your timing and detects knocks and pinging in your block-yes you want to change it ~$110
--------and yeah they will effect performance
..........to the best of my knowledge
...........a lot more info if you search..........
Old Jul 2, 2002 | 10:59 PM
02 Sensor
I still need to know what the symptoms are for a dead O2 sensor, please.
Old Jul 3, 2002 | 05:06 AM
mzmtg's Avatar
Minister of Silly Walks
Re: 02 Sensor
Those codes would not result from a dead O2 sensor...you'd be getting an O2 sensor code.
Old Jul 3, 2002 | 02:26 PM
munji's Avatar
Re: ECU Test
Just try looking around the net for a good price, I replaced mine a short while ago, I got mine from thepartsbin.com for ~$112 or so, they may be cheaper prices around..................I promise that you will get more info by searching threads though..............
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
