New oils for "High Mileage Engines"..
Hey All,
Pennzoil, Quaker State and just about everyone else has come out with a new oil blend for high mileage engines...has anyone used them yet? Has anyone heard about whether they're really effective or not? Just curious...had my oil change yesterday and tried it (Quaker State one) I'll let you know if I notice anything!
-Chad
-Chad
Re: New oils for "High Mileage Engines"..
Originally posted by maximachad
Hey All,
-Chad
Hey All,
-Chad
However, as someone that researched engine oils as part of my work with a Formula SAE team, nothing beats a high quality synthetic like AMSOIL. With today's modern engines, I wouldn't run anything other than AMSOIL or Redline (AMSOIL for street cars, and occasional race cars, Redline for race car alone, primarily because Redline has shorter drain intervals than AMSOIL). However, if I had an old 3800V6 with over 100K miles, and had minor leaks and consumption, I'd probably use such high mileage blends now and then.
Re: Re: New oils for "High Mileage Engines"..
Originally posted by Sin
One thing I would monitor is oil level, especially if you have had any oil leakage or consumption. These formulations, as you probably know, have a relatively high content of seal conditioners primarily, and slightly higher concentrations of detergents.
-Chad
Re: Re: Re: New oils for "High Mileage Engines"..
Thanks for the info...I haven't had any problems at all - no leaks or oil consumption or anything like that. I was actually trying to prevent some of that stuff...preventative maintenance. Thanks again,
-Chad
-Chad
Re: Re: Re: Re: Re: New oils for "High Mileage Engines"..
Originally posted by Pervis Anathema
Would it be bad for the motor to change to a synthetic? Especially on high mileage motors?
Is this bad for the engine? The worst that can happen is that you might need to replace the seals. Whether this is "bad" and outweighs the benefits you could realize from synthetic oil is really up to you.
Re: Re: Re: Re: Re: Re: New oils for "High Mileage Engines"..
Originally posted by iwannabmw
It's not so much high mileage motors that may have a problem, but poorly maintained one's. Many people have switched to synthetic with over 100K on the motors with no problems. The odds are better that you may have seal leakage issues the higher the mileage you switch over, but it's not a certainty. The reason seals can start leaking is that in an engine that is used hard with petroleum oil, and not maintained as well as it really should, sludge can build up around the seals, depriving the seals of oil. The oil actually is supposed to condition the seals and keep them supple. Since the oil can't get to the seal, it dries up and can crack. The sludge build-up around the seal prevents any leaks. When a synthetic is now used and the sludge is cleaned away, the oil can leak past the already damaged seal. Sometimes, the seal will re-swell slowly and the leak will stop. Other times it is too far gone and it really needs to be replaced. The leaking is not caused by the synthetic oil itself, rather the problem was already there and caused by petroleum oils, synthetics just bring the problem to the surface.
Using Maxlife now..
Hi. I'm using Valvoline Maxlife at the present time. Started using the oil since April of this year. So far so good. No oil consumption since April. My '99 Maxima doesn't burn oil even before using Maxlife. Hopefully, in the long-run this oil really does reduce oil consumption.
Re: Re: Using Maxlife now..
Originally posted by 1SikMax
Also keep in mind not to just jump into synthetic. Ease into it with each oil change and once you go syn it's not wise to go back. I usually stick with mobil 1.
Re: Re: Re: Using Maxlife now..
Very old myth. There is nothing wrong with switching back and forth between conventional and synthetic lubricants. It's a waste of money, but it won't cause any problems.
Just drain the pan, replace the filter and refill it with some synthetic of your choice (Mobil 1, Redline, Castrol, whatever).
You can also switch back anytime or mix them if you really feel like wasting money. But it won't hurt a thing to do so. Just make sure it's the same viscosity....
-RMB
spencerwh1
Jun 30, 2016 05:44 AM
RWCreative
Sep 21, 2015 11:01 AM
sdotcarter
Sep 2, 2015 09:53 PM
