just installed my intake and i have a question
Old Jul 4, 2002 | 06:40 AM
a1281b's Avatar
My question is what do i do with the senser that was
inside the air box?
thanks for any help
Old Jul 4, 2002 | 08:51 AM
njmaxseltd's Avatar
What kind of intake are you getting?
There should be a spot to put that sensor in if it's a CIA.
If your getting a pop charger, most guys mount that sensor in the pop charger.
It's a good idea to try to get that sensor in the intake air flow and you may have to do some modification to get it in there.
Old Jul 4, 2002 | 08:59 AM
a1281b's Avatar
i got this Air Filter from ebay http://cgi.ebay.com/ebaymotors/ws/eB...tem=1838334760
so what do i have to do with senser?
Old Jul 4, 2002 | 09:01 AM
Requin6's Avatar
i have the newer style JWT and there is no where to cut a hole and bolt it into the filter...so i mounted the sensor in between where the filter bolts up and the filter itself...kind of droppped the wire in there and bolted it up. but i have seen people with the stillen cone that have drilled a hole at the very end of the filter and bolted it up.
Old Jul 4, 2002 | 09:26 AM
I30tMikeD's Avatar
I put mine right infront of the filter on the outside. There is a bolt right next to where my filter is, I just added it to that. It hanges about an inch from the filter. From what I know, the sensor needs to be reading the temp of the air coming into the filter. So as long as it is close to the filter it should be O.K.
If someone thinks this is a bad place let me know. I just copied what some other org. members did. But I am 99% positive the placement is just fine.
Old Jul 7, 2002 | 12:06 AM
jcy98maxse's Avatar
Turbo is too much fun!
does anyone know where the location of the sensor on a 98?? I've been trying to find it but don't know what it looks like.
95Maxi
Aug 29, 2015 09:38 PM
98nismomax
Aug 26, 2015 03:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
