help, just installed hybrid but a problem!!!
Old Jul 6, 2002 | 01:06 PM
jcy98maxse's Avatar
Turbo is too much fun!
I just installed my Hybrid intake. It wasn't as difficult as I thought, I followed all the instructions. The first time I turn on the engine, the enigine lights did not come on, after half and hour or so it finally did. I thought this was normal so I reset the ecu.
Now here is the problem: After resetting the ecu, The engine light goes off and stays off however when I turnm off the car and back on again, the light stays on wtf????
I am really confuse so please help!
thanx
Old Jul 6, 2002 | 01:15 PM
KINGMAX's Avatar
Check and see what codes it is pulling, and also what did you do with your MAF sensor?
Old Jul 6, 2002 | 01:19 PM
jcy98maxse's Avatar
I just pulled it and it said air intake temp sensor? which I have no clue where its at??
Old Jul 6, 2002 | 01:34 PM
KINGMAX's Avatar
OK, I may be wrong here but when I helped my friend install his intake he took out a sensor and I think he covered it up but I could be wrong.
Old Jul 6, 2002 | 01:43 PM
KINGMAX's Avatar
Ok, I just talked to my friend, and he said it was the air temp sensor he took out but he put it back in. It is where the ram air opening is at the front of the engine bay, and btw it wasn't your maf 'cause your car would sputter and die with that unplugged.
Old Jul 6, 2002 | 03:12 PM
Jamsan's Avatar
did u start the car without your intake fully together? if so its the MAF code...just make sure its all together, no leaks, and reset the ECU and it should be fine....pull the codes first, but im pretty confident its that
Old Jul 6, 2002 | 03:31 PM
jcy98maxse's Avatar
everything was together before I started the car. I pulled the codes and its the air temp sens. I'm still trying to figure which one of the plugs it is, I unplugged and plugged the one that was screw to the front of the ramair scoop, theres also a plug at the end of it just before where the stock air box would have been.
Old Jul 6, 2002 | 03:39 PM
Jamsan's Avatar
ok so, plug the sensor back in, if you took out the scoop, then just take out the piece that it was plugged into, and tie the harness down to something and let it hang there...then reset the ECU and it shold be gone......
i guess it wasnt the MAF
Old Jul 6, 2002 | 03:42 PM
jcy98maxse's Avatar
sp ypu're talking bout the one in the rear right? just wasnna make sure.
Old Jul 6, 2002 | 03:43 PM
Jamsan's Avatar
yes the one at the further back of the piping in the air scoop....the one in the front that was bolted on is the boost sensor....just tie that down as well
Old Jul 6, 2002 | 03:57 PM
jcy98maxse's Avatar
I just put the hole plug in the pipe should that work also?>
Just went for a short drive, everything seems ok, the engine lights hasn't come on yet so I think it'll be okay.
thanx for your help guys
Old Jul 6, 2002 | 09:26 PM
jcy98maxse's Avatar
Ok !!!! My d*mn light came on again. I already remove the plug and the thing that was plugging into from the rear part of the air dam and stuck it into the upper pipe. Wtf why did the light come back on even after resetting the ecu??? was that the correct sensor (it was a plastic black thing attached to a gray plug). I'm stumped I don't know what to do next
Old Jul 6, 2002 | 11:13 PM
iregula's Avatar
eesh i hope that doesnt happen to me when i order the franken upper
Old Jul 7, 2002 | 12:09 AM
jcy98maxse's Avatar
OKay, I look at my haynes manual. I look at my stock airbox, and all over the intake area and still can find the air temp sensor, I remember only unplugging the MAF. I also unplugged and plugged the thing @ the end of the ram air scoop when I took it out. SO where is the d*mn air temp sensor on my 98 max???
Old Jul 7, 2002 | 12:22 AM
Dave Holmes's Avatar
If I'm right, the air temp sensor should be (on a stock intake system) below the air box, in the duct that goes up in the bottom of the box. It's just pushed in a hole in the duct.
Dave
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
