Clicking Noise help me please :(
Old Jul 7, 2002 | 08:06 AM
Mmmaxx's Avatar
So im driving home from work yesterday and notice, an od clicking or "clunking" noise not really loud but defintly not the norm. It only seems to happen when I p8sh the accelerator quick, or when i rev the engine. its not a constant noise either if i hold the pedal downa bit and let it sit around 2,000 rpms it doesn't make the noise. its just like a quick little clicck clunk..now to me not know **** about engines, thought it sounded like a rock or something kicking around somewhere it shouldn't be however I have heard the noise before on other cars. Anyone have any idea what this might be? thanks.
EDIT: actually, if you can think of the noise a car makes when it stalls or overheats while going a god 40 mph the click clunck noise the pistons make when they suddenyl loose power or whatever, its almost like that noise.
Old Jul 7, 2002 | 08:08 AM
mzmtg's Avatar
Minister of Silly Walks
Sounds like engine knock. You could have a bad knock sensor, a common problem.
Pull the codes from your ECU, and see if you get code 0304...
Old Jul 7, 2002 | 08:11 AM
Mmmaxx's Avatar
hmm
Doesn't the check engine light have to be on for it to post codes? and if not it only does 1 code or somethin, where did I read that heh, anyway my check engine light isn't on. Code thing still useable?
Old Jul 7, 2002 | 08:19 AM
Lime's Avatar
http://vbxmaxima.8m.com/ecu.html
this will help you in how to check the ECU.
Old Jul 7, 2002 | 09:46 AM
mzmtg's Avatar
Re: hmm
A bad knock sensor will not cause the check engine light to come on, but if you get the code it's bad...
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
