Reprogram ECU?
Old Jul 8, 2002 | 12:35 AM
|\|issan|\/|ax's Avatar
Reprogram ECU?
I am on a low budget...so I am looking for "cheap and easy" upgrades...Is it possible to reprogram the ECU using software on a laptop? I am wondering because I found a Parallel Port in the front right of the car (inside) behind a piece of plastic.
Old Jul 8, 2002 | 12:37 AM
mtrai760's Avatar
'Trynna' is not a word
Nope, and even if you could, you would have to know what you were doing, and need a dyno to do it. JWT and Gforce are the only options right now...
Old Jul 8, 2002 | 12:38 AM
Reprogram ECU?
As Homer Simpsons would say, "Do'h"!!!!!
Old Jul 8, 2002 | 12:39 AM
Reprogram ECU?
Wait what about that Parallel Port? Is that for the people with the Dyno?
Old Jul 8, 2002 | 12:41 AM
mtrai760's Avatar
Re: Reprogram ECU?
The port you probably saw is for running diagnostics on the car.
Old Jul 8, 2002 | 12:42 AM
Can I run those tests?
Old Jul 8, 2002 | 12:48 AM
mtrai760's Avatar
You can get the codes out of your ECU, but you need a special machine to run diagnostics, you may be able to pick up a generic OBD II reader and check it with that, but it won't tell you the whole story, nor will you be able to see any information, usually only dealers and shops have those kinds of machines, and they charge ya $$$ to run a test, which is pretty much pointless unless your car is not running right.
Old Jul 8, 2002 | 12:07 PM
forest's Avatar
Jetchip also has an ECU pkg. DOn't think they are using JWT or GFOrce for the proramming.
Old Jul 8, 2002 | 03:00 PM
iregula's Avatar
yeh that stuff is nice
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
