PCV Valve Replacement
Old Jul 8, 2002 | 09:45 AM
WaarrEagle's Avatar
I have a new PCV valve that I am going to put in my car for the 60k service. I have seen a pic of where the valve is but I can't find anywhere how to install it. I did a search and everyone talked about it but never said how to do it. Are there any sites with instructions or can someone just tell me real quick how to do it. Thanks.
Old Jul 8, 2002 | 10:22 AM
rmb's Avatar
rmb
Re: PCV Valve Replacement
The old one just pulls right out. The new one plugs right back into that black rubber grommet. Oil the new one up a bit to make it easier to get the old rubber pieces attached again.
!!!!! Be real careful not to push the whole rubber grommet into the engine as some people have done. !!!!!!!
It's in an ugly place for someone with large hands. I ended up using two really long needle-nose pliers that made it a snap....
-RMB
Old Jul 8, 2002 | 10:50 AM
RI-Max's Avatar
don't let the grommet fall in the valve cover!!!!lol i did it sucked i put silcone on the new grommet and on the valve so it just slides right IN! hehe
Old Jul 8, 2002 | 11:10 AM
breaux124's Avatar
Just did this a few weeks ago.
http://integra.vtec.net/geeser/megam...v_location.jpg
It's really easy with these tips.
- If you have a FSTB, it might help to remove it.
- Get needle nose or some type of pliers
- The PCV valve is connected to a rubber hose, on the other end of the rubber hose it's connected to a metal tube. That metal tube is bolted into the manifold. Unbolt that hose, and this will give you more play so that you can easily unclip and remove the rubber hose.
Once you've unclipped the hose from the PCV, just pull it out. Then put the new one in and put the rubber hose back on. Put the bolt back in the manifold and your done.
If you don't remove that bolt, it makes it much harder to get the rubber hose back onto the PCV valve, since you don't have much wiggle room.
Old Jul 8, 2002 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
So how do you know your old one is toast?
Old Jul 8, 2002 | 11:26 AM
Lime's Avatar
The idle will be rough, but of course, this can be a result of other problems. It's kind of hard to know.
Old Jul 8, 2002 | 11:47 AM
breaux124's Avatar
Didn't really know it was toast, just did it as part of the 60K mile tune-up. I think the part was like $7-$8.
But I did notice it smoothed out my idle. Sometimes my idle would be high (already warmed up), and then eventually go back to normal range. But now it's always at normal range after it's warmed up. And this was the only thing I change since.
I've also noticed I'm getting a little better gas milage, but that could be because my idle what higher that it should be, before. Just change it, it's cheap and very easy to do. If you remove that bolt in the manifold it'll take you 15minutes tops.
CorollaULEV
30
Aug 9, 2021 08:11 PM
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
