FYI: Oxygen Sensors (Bosch) for $77.99!
Old Jul 9, 2002 | 07:11 PM
maximachad's Avatar
Lifetime Maxer
Just wanted to let you all know that I did a little shopping around for oxygen sensors - found them at AUTOZONE (www.autozone.com) for 77.99 each! The front manifold sensor and rear manifold sensors are the same price. I have a store near me, so I don't even have to pay shipping. To think that this same sensor is $178 at my Nissan dealer
-Chad
Old Jul 9, 2002 | 07:29 PM
Jamsan's Avatar
i know Bosch spark plugs suck *** as opposed to the OEM plugs...so maybe its teh same with the o2 sensors...but then again, what can one sensor do different from the other?
Old Jul 9, 2002 | 07:32 PM
davey6693's Avatar
Yes I'd heard that about the spark plugs, but Bosch are the OEM oxygen sensors I believe. Great price on those..
Old Jul 9, 2002 | 08:23 PM
Ramius83
When it comes to those VERY important sensors, it is always in the best interest of the driver to get OEM.......
Old Jul 10, 2002 | 12:17 AM
Chunger's Avatar
My other car is a Hybrid
OEM is made by BOSCH...
Old Jul 10, 2002 | 12:52 AM
buss95max's Avatar
Old Jul 10, 2002 | 08:56 AM
Rickalodeon's Avatar
Re: FYI: Oxygen Sensors (Bosch) for $77.99!
-Chad
Just spoke to the Acme Auto folks who claim they will match the Autozone price. (for those of you with Acme Auto's near you)
Old Jul 10, 2002 | 09:22 AM
tmkforever's Avatar
What is wrong with the Bosch spark plugs? And which ones are supposed to be bad? They make a ton.
-Jon
Old Jul 10, 2002 | 09:46 AM
jayanth's Avatar
Bosch does not make titanium sensors which was in my max (rear O2).Look for NTK sensors they outperform Bosch.I bought bosch but it did not fit in as it was too big.Take your old O2 sensor and compare with the Bosch from autozone.
Old Jul 10, 2002 | 12:15 PM
SillePimp's Avatar
-Chad
OE replacement for the bank sensors can be bought at www.buyoxygensensors.com.
Old Jul 10, 2002 | 12:20 PM
Chunger's Avatar
Never heard of titanium in O2 sensors... but when I took off both my factory front O2s for replacement... Bosch was stamped on it...
Old Jul 10, 2002 | 12:48 PM
jayanth's Avatar
Read this article on O2 sensors,
The titanium oxygen sensor is a whole different animal (it's often called "titania," but that's the name of the fairy queen in English folklore, not that of the metallic element). Nissan is the biggest user. In '93, for example, every model except the Maxima and the V6 pickup had titanium sensors. There's also a sprinkling of others on the road. AMC used it on Jeeps from '87 to '90, but when Chrysler bought that company, all engines were switched over to Mopar's own corporate system, which requires a zirconium sensor. Some Toyotas have had it, too, such as the '89 Corolla GTS.
Instead of generating voltage, its resistance changes dramatically when the oxygen content of the exhaust reflects stoichiometry, so it's used to modify a reference signal (typically one volt) from the computer in much the same way as a coolant temperature sensor. What happens is oxygen blocks the passage of electrons through the TiO2 element, and resistance rises sharply as the mix goes lean.
It's much less susceptible to lead poisoning than zirconium, but that's not a consideration anymore. On the other hand, it can't tolerate anti-freeze, and it needs to be kept at a very stable temperature in order to produce an accurate signal, so all specimens are electrically heated.
How can you tell whether or not the sensor you're looking at is titanium? In the case of Nissan, it'll have 12mm threads instead of the standard 18mm. Sometimes, its wire will be color-coded red. In every instance, there's no atmospheric vent.
Old Jul 10, 2002 | 02:21 PM
Ramius83
Are the rear bank and front bank o2 sensors the same?
Old Jul 10, 2002 | 04:09 PM
Chunger's Avatar
Different part # - mostly due to the harness length...
Old Jul 10, 2002 | 04:27 PM
Ramius83
Re: Re: FYI: Oxygen Sensors (Bosch) for $77.99!
So are these the right sensors that I would need to buy?????
Old Jul 11, 2002 | 12:48 PM
SillePimp's Avatar
Re: Re: Re: FYI: Oxygen Sensors (Bosch) for $77.99!
I think the OE has 3 wires. According to their website, these have 3 wires and goes directly into the OE harness.
Old Jul 11, 2002 | 08:54 PM
krbga's Avatar
What started out easy...
...has become confusing.
Old Jul 12, 2002 | 05:31 AM
goldmax's Avatar
Why exactly are you changing the O2 sensors? The maintenance schedule doesn't show a need to change them out. Are you having problems or have forum members found that it restores performance? Just curious!
Old Jul 12, 2002 | 06:36 AM
Chillin's Avatar
3 sensors
i went to the dealership becuz my check light came on. they told me that both sensors were out; the front and rear. Then in the next sentence, they told me $500 to change both. The bad thing about it is, if i had $500, i would've gotten it done. Good thing i didn't have $500, becuz i called autozone and they told me about the $77 sensors. i bought both and a maxima manual. The only problem i ran into is that the manual showed a picture of two sensors, one on the manifold(front) and one on the cat. conveter - which i thought was the rear sensor. So i pulled at the sensor on the converter to get it out and come to find out it was different from the one i bought at autozone. After calling autozone, they told me the sensors were for the manifold and not cat. converter. They didn't have the any knowledge of the car having a cat. converter sensor. Long story short, i had to buy the cat. converter sensor from somewhere else but i did all three on my own for less than $250.00.
Old Jul 12, 2002 | 11:37 AM
JustMaxin96's Avatar
Re: 3 sensors
I am dealing with a similar problem.. does anybody know which sensor is bank one sensor one?? Is it in the y-pipe? There is two in the Y of a 96 SE and one in the cat...which one should I change?? Please advise any pics or links are always more than appriciated!!!
Old Jul 12, 2002 | 12:45 PM
Nick97SE's Avatar
I think my Rear Heated o2 Sensor needs to be replaced because my check engine light is on and that is the code that it's throwing. Which sensor should I buy for this?
Thanks,
-Nick
Old Jul 12, 2002 | 12:55 PM
maximaseefu's Avatar
I need to replace all mine
So I wonder if anyone can post directions on locations and what tools I will need to replace all my O2 sensors.
Old Jul 12, 2002 | 01:01 PM
Max_Gator's Avatar
Re: Re: 3 sensors
If I recall correctly there was a recall relating to the 02 sensors on the 96.
i'd call nissan to confirm. (of course, even if there was a recall, they will tell you there wasn't)
Old Jul 12, 2002 | 01:28 PM
Re: Re: Re: 3 sensors
Is that a fact? Does anybody have any proof of this? I just bought an O2 sensor and I would love to get my money back. Does anyone know which O2 sensor is bank 1 sensor 1? on a 96.
Thanks a lot
Old Jul 12, 2002 | 01:30 PM
Max_Gator's Avatar
Re: Re: Re: Re: 3 sensors
Thanks a lot
Well, I did a search and it seems there is some controversy over whether it was a recall or not.
http://forums.maxima.org/search.php?...der=descending
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
