FS: 02-03 headlight lens + 00-01 foglight + Gauge cluster/parts
Old Oct 27, 2007 | 01:44 AM
Dr. Roy's Avatar
1. lenses sold
2. Foglight $30 shipped
Drivers side 00-01 OEM nissan foglight, the lens has typical markings from road debris but lens is clear w/o haze. Only defect on this unit is it is missing the plug, otherwise in excellent condition
3.Gauge cluster parts $20 shipped
-Top cluster is from a 00 5speed, does not work + no clear plastic. the SE gauges in the bottom of photo belong to this cluster, the faces were melted and warped during a botched attempt to make gauges brighter by using higher wattage bulbs, only the gas gauge escaped damage
-Bottom cluster is from a 00 auto - functioning fine when gauges pulled...somewhere around 105K on the odometer
Old Oct 27, 2007 | 07:18 AM
KJVA67's Avatar
STUCK IN ATL
From: JACKSONVILLE, FL. STUCK IN ATL FOR THE TIME BEING
im sent
Old Oct 31, 2007 | 03:20 PM
Dr. Roy's Avatar
leses sold to KJVA67 and nsnrider,
gauge parts and fog light still available
Old Nov 9, 2007 | 06:53 PM
Dr. Roy's Avatar
BUMP...........
Old Nov 9, 2007 | 08:57 PM
mitymax03's Avatar
if u have the clear plastic piece from any of the gauges that ur willin to part, ill buy one from u if its in good condition .lmk
Old Nov 9, 2007 | 09:06 PM
02Maximan's Avatar
I'm looking for the same thing.....
Old Nov 10, 2007 | 01:24 AM
Dr. Roy's Avatar
i have one, you can have just that piece or all the stuff in the photo - either way $20 shipped
Old Nov 10, 2007 | 12:43 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
would it be easy to put my gauges in the 00 auto speedometer? mine doesn't really work from 0-20 and jumps after a little. since you've had a lot of experience with it what do you think? thanks!
Old Nov 10, 2007 | 02:57 PM
Dr. Roy's Avatar
from what you describe, it sounds more like the gauge itself rather than the cluster, i have had similar symptoms after incorrectly removing the needle from gauges...gets stuck, sweeps slowly, ect.
as bad as it looks in the pic, the speedometer gauge does function; if you were to switch the motors it may take care of your problem.
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
