The Ultimate 03 Maxima SE/TE Partout......BOOM!
Old Apr 1, 2009 | 11:28 AM
  #241
Deckdout2's Avatar
Play with my balls
Originally Posted by mtrai760
Do you happen to have the fuel injector wiring plugs available?
I will check the motor tonight and see what part of that I have. Will get back to you.
Old Apr 3, 2009 | 08:12 AM
  #242
silverbulletmax03's Avatar
Want the center console plastic vent cover
How much for the center console plastic vent cover? I want to replace my stock with your silver-painted cover. Can paypal, live in Raleigh, NC.
Old Apr 3, 2009 | 09:43 AM
  #243
Deckdout2's Avatar
Play with my balls
sent pm.
Old Apr 3, 2009 | 10:40 AM
  #244
mtrai760's Avatar
'Trynna' is not a word
Anything?
Old Apr 3, 2009 | 11:52 AM
  #245
Deckdout2's Avatar
Play with my balls
Anything?
Do you know if this is on the main harness or if there's a secondary harness for it? I have the fuel rail, but not sure exactly which part you will be needing. Any pics or a diagram would help.
Old Apr 3, 2009 | 12:18 PM
  #246
mtrai760's Avatar
I need the 3 plugs circled in red below, along with the 3 under the intake manifold connected to the rear fuel injectors. Basically, I just need the 6electrical plugs to the fuel injectors, along with a decent amount of leadwire to each, so I can solder them into a new harness. Ready to purchase. Thanks.
Old Apr 3, 2009 | 01:13 PM
  #247
Deckdout2's Avatar
Play with my balls
Got ya.
Old Apr 3, 2009 | 02:39 PM
  #248
Aaron92SE's Avatar
NWP Engineering.com
Got ya.
Didn't I buy the full engine control harness from that car? If so, then those injector connectors are on my harness.
BTW, I need the two o2 sensors that are further down the exhaust stream. They are called "Oxygen Sensor #2 Bank 1" and "Oxygen Sensor #2 Bank 2". I don't need the ones that are in the stock exhaust manifolds up close to the heads.
Give me a call back on my cell as soon as you know. Thanks.
Old Apr 3, 2009 | 02:58 PM
  #249
vastmax's Avatar
Yeah, I told P they were on the main harness, also, I believe we're keeping the O2's to ourselves, but maybe we can work something special out for you buddy...
Old Apr 3, 2009 | 03:10 PM
  #250
Aaron92SE's Avatar
NWP Engineering.com
That would be awesome if you guys can help me out ONCE AGAIN.
I called P a little while ago and left a voicemail asking about them and then I noticed this thread.
I am also in need of a midpipe to connect my TB to MAF. I'd prefer if it was a decent aftermarket piece so I can easily tap my nitrous nozzle in it.
Old Apr 3, 2009 | 03:34 PM
  #251
mtrai760's Avatar
Well that sucks, I've been trying to find these damn connectors for months...
Old Apr 3, 2009 | 05:13 PM
  #252
Aaron92SE's Avatar
NWP Engineering.com
Sorry man. I have a QR25DE engine harness here and was hoping that some of the injector connectors were on it, but it's not. Those 4 connectors must be on a subharness connector. And I couldn't find any other connectors on that harness that would work for you. I also have 3 VQ35DE injector connectors that came on my engine from the salvage yard when they cut the engine control harness. But they cut those 3 connectors flush with the connector!
I wish I could help ya, but I got nothing. Sorry.
Old Apr 4, 2009 | 09:48 AM
  #253
mtrai760's Avatar
No problem Aaron, thanks for looking.
Old Apr 4, 2009 | 10:44 AM
  #254
Deckdout2's Avatar
Play with my balls
Hey guys. I'm going to my motor now and verifying for sure. You guys might be right, and they might be on the main harness, but I thought that there was a secondary harness for these. I'll check and report back for sure.
Old Apr 4, 2009 | 11:56 AM
  #255
wade's Avatar
how much for the driver door window regulator and motor
shipped to: J4Y3C9 Canada?
Old Apr 4, 2009 | 12:10 PM
  #256
Aaron92SE's Avatar
NWP Engineering.com
The harness I bought from you has 3 LH injector connectors. But the RH injector subharness is still on your car I bet. It is the same exact stretch of wire that has the oil pressure switch connector and is attached to the bracket for the EVAP solenoid.
So you should have 3 of the connectors he needs.
Old Apr 4, 2009 | 05:28 PM
  #257
mwoods07's Avatar
Hi, do you still have the shifter assembly? Will you separate it out or must you sell the entire assembly together?
Thanks,
Mike
Old Apr 5, 2009 | 06:43 AM
  #258
vastmax's Avatar
Thanks,
Mike
that went with the car, sorry.
Old Apr 6, 2009 | 07:17 AM
  #259
Deckdout2's Avatar
Play with my balls
This is confirmed. I do have only 3 of these connectors. The other 3 are on your main harness. Thanks Aaron.
Old Apr 6, 2009 | 07:18 AM
  #260
Deckdout2's Avatar
Play with my balls
I think that went with the car as well, but let me check.
Old Apr 6, 2009 | 11:45 AM
  #261
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Hi. I am in need of some brake dust. Preferably from rotors that were warped.
Old Apr 6, 2009 | 02:09 PM
  #262
Deckdout2's Avatar
Play with my balls
$425.00 Shipped for the brake dust. I'll throw in the warped rotors for free. Shoot me a paypal and I'll get these right out to you. Thanks.
Old Apr 6, 2009 | 02:37 PM
  #263
Lanaue's Avatar
Do you have a front lic plate holder to 21234
Old Apr 6, 2009 | 03:41 PM
  #264
vastmax's Avatar
not available, sorry
Old Apr 6, 2009 | 05:30 PM
  #265
Aaron92SE's Avatar
NWP Engineering.com
You wouldn't happen to have a spare o2 sensor connector, would you? I need the male connector that goes on the sensor itself. I would prefer that this came off a bad o2 sensor. I just need the pigtail.
Edit: Here's the connector I need:
Old Apr 6, 2009 | 06:50 PM
  #266
Lanaue's Avatar
how about the grill to 21234?
Old Apr 6, 2009 | 11:09 PM
  #267
NOplz's Avatar
Need mud guards...look at the red circles. Let me know if you still have any. Ship to 06269.
Old Apr 8, 2009 | 05:56 AM
  #268
Deckdout2's Avatar
Play with my balls
We spoke on the phone. Thanks bud.
That is no longer available. Sorry
Shot you a pm. Thanks.
Old Apr 11, 2009 | 12:04 PM
  #269
wsrivers's Avatar
Is the tail light harness available and if so how much shipped 07018?
Old Apr 11, 2009 | 01:01 PM
  #270
importcf's Avatar
how much for the headunit, fit kit, and harnesses to 02478
Old Apr 11, 2009 | 07:57 PM
  #271
NewfoundlandDud's Avatar
Hey man, I need these:
http://forums.maxima.org/5th-generat...ml#post6977920
Please let me know if you have them.
Old Apr 11, 2009 | 08:03 PM
  #272
Deckdout2's Avatar
Play with my balls
PM Sent
The one in this thread is not available, but I have and Eclipse 6610 for sale if you're interested.
This isn't available anymore. Sorry.
Old Apr 11, 2009 | 09:55 PM
  #273
Cisco93lude's Avatar
front turn signal harness if you wanna cut it off for me! thanks
Old Apr 12, 2009 | 07:31 PM
  #274
Deckdout2's Avatar
Play with my balls
Car is now gone, but have other parts available. These were cut off for someone already. Sorry.
Old Apr 13, 2009 | 10:09 AM
  #275
knight_yyz's Avatar
Toolie
I have 2 of these, one brand new and one used. Pm me an offer, shipping from toronto Ontario
Old Apr 23, 2009 | 06:01 AM
  #276
toastedoats's Avatar
Passenger front seatbelt assembly?
Old Apr 23, 2009 | 07:11 AM
  #277
Deckdout2's Avatar
Play with my balls
That has been sold. Sorry.
Old Apr 27, 2009 | 04:35 PM
  #278
Ahmad_1290's Avatar
Do you have the driver side mirror glass?
Old Apr 28, 2009 | 06:19 AM
  #279
Deckdout2's Avatar
Play with my balls
That's gone mang. Sorry.
Old Apr 28, 2009 | 11:59 AM
  #280
BLACKKILA.GTR's Avatar
any prts offff the the motor still availible.. need the coolant like.. the on right undrerneath the o2 sensors
