FL FS: 5th / 5.5 Gen Grounding kit
Old Sep 27, 2011 | 05:15 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
A note: The 4th Gen kit will install to a 95-99 I30 the 5th Gen kit will install on a 00-01 I30 and the 5.5 Gen Auto kit will install on a 02-04 I35 no modification or alteration needed.
The kit cost $59.00 ($54.50 if you choose Berkshire) SHIPPED (no extra charge!) anywhere in the US. Canadian and Mexican ordered will incur a $6.50 shipping fee however. The order form can be found at the top of this listing or here:
US Orders: http://shinjiduo.angelfire.com
Canadian or Mexican Orders: http://shinjiduo.angelfire.com/canadamexico/
As for the product; a grounding kit allows your electrical system to work more efficiently by siphoning off power spikes caused by your cars alternator do to irregular power draws and rpm levels during it's operation. This allows for clean precise signals to be sent to the various CPUs and sensors that need them. This has many benefits which include:
- Higher gas mileage
- Better radio reception
- Faster power windows
- Brighter interior and exterior lights
- Smoother idle
- Faster Rev
- Faster automatic transmission shifts
- Heavy draw electrical accessories like your fan does not cause light dimming or effect your idle in any way.
- Longer alternator life
- Less voltage spikes means aftermarket LEDs will be far less likely to burn out in your car. (Especially protects on start up)
- Aftermarket LEDs will cut all the way off (If you have that problem).
- Made 4AWG (2x Thicker than 8Gauge) Stinger Audio wire and 3M nickel coated copper terminal ends.
- Step by step picture intructions provided online in PDF format.
- Comes with all mounting equipment needed.
- In General your car will feel like new in some ways even better than new in others. (Especially the auto shifts)
The kit cost $59.00 SHIPPED (no extra charge!) anywhere in the US. Canadian and Mexican ordered will incur a $6.50 shipping fee however. The order form can be found at the top of this listing or here:
I am also offer another option for those of us that might want all of the benfits of the kit but also save a few dollars; Berkshire marine wire is a little less flexible than Stinger (but plenty flexible enough fo this application) but it actually has a little more copper in it for better conductivity (Best in the industry) and plus it is made right here in the US out of Leeds, MA (A little hypocritical since we drive Japanese cars, I know.). That option is also available on the order form and will drop the kit's price from $59 to $54.50 Shipped but is only in one color: plain black. Here are the color choices:
Translucent Black (Personal Favorite)
Crimson Red
Carbon Grey
Clear Silver
Island Blue
Berkshire
Old Sep 27, 2011 | 05:28 PM
nismomaxx's Avatar
So 52 shipped for the Berkshire kit?
Old Sep 27, 2011 | 05:32 PM
Shinjiduo's Avatar
Yes $52 shipped you will see the option on the order form. Just remeber to put your gen and transmission in the message box for the order so I know which kit to make.
Old Sep 28, 2011 | 06:54 AM
Xpcgamer's Avatar
Good luck brother. Product looks good. Let me finish recouping from buying springs and the front lip and I'll pick one up from you then.
Old Sep 29, 2011 | 11:26 AM
Shinjiduo's Avatar
Bump
Old Oct 2, 2011 | 05:59 PM
Shinjiduo's Avatar
Bump
Old Oct 4, 2011 | 08:25 AM
Shinjiduo's Avatar
Bump
Old Oct 6, 2011 | 06:19 PM
Shinjiduo's Avatar
Bump
Old Oct 9, 2011 | 09:13 PM
Shinjiduo's Avatar
Bump
Old Oct 12, 2011 | 04:59 PM
Shinjiduo's Avatar
Bump
Old Oct 13, 2011 | 09:54 AM
clintb3astwood's Avatar
How many grounds come in the kit and where are they installed?
Old Oct 13, 2011 | 11:26 AM
Prophecy99's Avatar
do you make g kits for any other makes? like a 02 acura rsx for my brother?
Old Oct 13, 2011 | 08:09 PM
Shinjiduo's Avatar
Just go to my order form and click the instructions tab for full instructions and pics for all my kits.
Old Oct 15, 2011 | 05:13 PM
Shinjiduo's Avatar
Bump
Old Oct 20, 2011 | 10:29 AM
Shinjiduo's Avatar
Bump
Old Oct 23, 2011 | 09:41 AM
Shinjiduo's Avatar
Bump
Old Oct 26, 2011 | 02:27 PM
Shinjiduo's Avatar
Bump
Old Nov 1, 2011 | 07:55 AM
Shinjiduo's Avatar
Bump
Old Nov 4, 2011 | 03:09 PM
om4r's Avatar
Pm sent
Old Nov 8, 2011 | 05:46 PM
Shinjiduo's Avatar
Bump
Old Nov 12, 2011 | 09:33 AM
Shinjiduo's Avatar
Bump
Old Nov 14, 2011 | 07:28 AM
paxan600's Avatar
Just payd for mine! 5.5 6spd in red!
Old Nov 16, 2011 | 04:14 PM
Shinjiduo's Avatar
Bump
Old Nov 17, 2011 | 09:07 PM
seastone14's Avatar
Install is going well except for the fact that there is no 8MM bolt on the end of my starter but instead a rusty screw(OEM, have yet to successfully remove it). Also, when tightening the bolt by my dipstick it got to a point where there was too little clearance between the motor and bolt to continue tightening with a socket(and a wrench is too long to fit), leaving the cable end incompletely tightened down.
Let me know if these are problems you encountered and if you did how I should overcome them.
Old Nov 24, 2011 | 05:59 PM
Shinjiduo's Avatar
Bump
Old Dec 4, 2011 | 10:37 AM
Shinjiduo's Avatar
Bump
Old Dec 10, 2011 | 07:21 PM
Shinjiduo's Avatar
Bump
Old Dec 12, 2011 | 10:06 AM
Shinjiduo's Avatar
Bump
Old Dec 14, 2011 | 09:46 PM
Shinjiduo's Avatar
bump
Old Dec 20, 2011 | 11:38 AM
Shinjiduo's Avatar
Bump
Old Dec 22, 2011 | 07:32 PM
artilarygoboom's Avatar
does this realy increase gas milage? doesnt sound rite to me
Old Dec 26, 2011 | 10:18 AM
Shinjiduo's Avatar
Bump
Old Dec 26, 2011 | 10:59 AM
fishtale6spd's Avatar
Ok so is this pushed towards the auto Ppl I got a 6spd still same pros just not the auto shift thing right
Old Dec 29, 2011 | 09:33 PM
Shinjiduo's Avatar
Based on what I have been told even the shifting is improved on 6 speeds but I do not claim it as I personally have no point of reference on a manual Maxima with the grounding upgrade already done. All the other effects however, are exactly the same between the Auto and Manual
Old Dec 29, 2011 | 11:05 PM
MAXXED_816's Avatar
Just placed an order!
Old Jan 3, 2012 | 10:56 PM
Shinjiduo's Avatar
Bump
Old Jan 11, 2012 | 08:37 AM
Shinjiduo's Avatar
Bump
Old Jan 11, 2012 | 08:47 PM
MAXXED_816's Avatar
Received my kit today, thanks man!
Old Jan 11, 2012 | 09:03 PM
X GARGOYLE X's Avatar
payment sent for 02 max 6speed in clear silver !!!
Old Jan 18, 2012 | 10:05 AM
Blue Mesa's Avatar
Are these still available?
