WA 00-01 Retrofit headlight buckets w/ TL Bi-X
These have been sitting here for a while now. Bought the headlights used and was planning to do complete make over with TL Bi-X and full Lumileds LEDs turn signal board.
TL Bi-X projectors are moddded with clear OEM ZKW lens of E92 BMW to produce the cleanest and sharpest cut off beam. OEM ZKW lens are pretty rare and expensive. The Projectors are aimed, fitted, and mounted on the reflector buckets with Iris Shrouds. High beam selenoids are also completely wired with universal 9006 connectors. All you need to do is to trim the back of the opening of your housing ( I will walk you thru ), put the buckets back to the it, sealed it , and you have the best HID light out there not too mention that you'll mostlikely be the first 5th Gen Maxima with Acura TL Bi-X Projectors.
Build Threads
http://forums.maxima.org/8740645-post568.html
I'm testing water for $360 shipped for the pair.
The reason I lost interest to completing this project was that the headlights lens was old and cloudy that even after complete restoration I couldn't get them back to new clear condition. One of the Bezel was also repaired and have big cut out on the turn signal area for LED fitting. On top of that I didn't have time to finish it and could use money for other project.
I could include the rest of the headlights, including the lens, housing, and bezel, just pay extra shipping.
Pm if you are serious about it
Build Threads
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
