FL FS: Blue 0AWG OFC Big Three Kit + Supplemental Starter Ground Only $60 Shipped!
Old Sep 6, 2014 | 02:10 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
The big three kit is the gold standard of electrical enhancement kits for people with High Output Alternators or aftermarket electronics installed in theri vehicle. This kit unlike a typical grounding kit works by creating a extremely low resistance direct bridge between the postive battery terminal and positive alternator post. This coupled with just as low resistance supplemental grounds at the battery and alternator leads to rapid and efficient charging of your battery which leads to no bogging down of the stock electrical set up when faced with extra loads associated with aftermarket electronics.
This kit also features a supplemental starter ground which works synergistically with the power feed bridge from the alternator to eliminate the need for the replacement of your stock battery cables for maximum utilization of the kit. This kit used 0 gauge wire which is 3x the copper that is found in 4 gauge wire and ensures extra smooth start up, smooth idle and smooth auto shifts. Along with eliminating flicker and dimming of lights when high electrical load is present. For instance, when the radio, lights and A/C is on and the cooling fan kicks in. This kit has gold plated copper terminal ends and is fused for protection of your car's electrical system. This kit will work with any 4th gen and every 5th/5.5 gen except the 5.5gen 6-speed (I can do a custom set up for 6-speeds if requested). I am looking for 60 shipped for the kit which will come with all needed mounting equipment and picture step by step directions. PM me if you are interested. Here is a picture of the item being sold:
vingodine
45
May 21, 2016 12:46 PM
fulloboost
Sep 12, 2015 08:03 AM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
