FL FS: Blue 0AWG OFC Big "3" Kit /Supplemental Starter Ground$45 Shipped! (only 12 hrs!)
Old Sep 12, 2014 | 09:13 AM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
The price posted on the thread title is only good until 12:10AM on 9/13/2014. I will not be in town for a week after that so please contact me via PM preferably prior to 10:00PM to answer questions and to give me time to ship out if you do purchase.
The big three kit is the gold standard of electrical enhancement kits for people with High Output Alternators or aftermarket electronics installed in theri vehicle. This kit unlike a typical grounding kit works by creating a extremely low resistance direct bridge between the postive battery terminal and positive alternator post. This coupled with just as low resistance supplemental grounds at the battery and alternator leads to rapid and efficient charging of your battery which leads to no bogging down of the stock electrical set up when faced with extra loads associated with aftermarket electronics.
This kit also features a supplemental starter ground which works synergistically with the power feed bridge from the alternator to eliminate the need for the replacement of your stock battery cables for maximum utilization of the kit. This kit used 0 gauge wire which is 3x the copper that is found in 4 gauge wire and ensures extra smooth start up, smooth idle and smooth auto shifts. Along with eliminating flicker and dimming of lights when high electrical load is present. For instance, when the radio, lights and A/C is on and the cooling fan kicks in. This kit has gold plated copper terminal ends and is fused for protection of your car's electrical system. This kit will work with any 4th gen and every 5th/5.5 gen except the 5.5gen 6-speed (I can do a custom set up for 6-speeds if requested). I am looking for 45 shipped (within the US) for the kit which will come with all needed mounting equipment and picture step by step directions. PM me if you are interested. Here is a picture of the item being sold:
Check out this thread if you need some more information:
The definitive Big Three thread on the org by Metal Maxima
Old Sep 12, 2014 | 04:03 PM
Unclejunebug's Avatar
PM'd
Old Sep 12, 2014 | 07:08 PM
Nawlinsboy2006's Avatar
Sent u a pm a while back never heard from u...
Old Sep 13, 2014 | 10:56 AM
nycspudz03's Avatar
Also sent a p.m...
vingodine
45
May 21, 2016 12:46 PM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
