CAN-Other Stillen Supercharger, Big Brake kits, $1700
Supercharger, Brake Kit and Shift light from a Stillen Maxima, sold as a package, shipped, $1700 obo.
Vortech V2 Supercharger Kit- bolt on with full instructions, K&N filter, complete with the possible exception of fasteners and small hoses, consumables, etc (major parts below). It has about 15,000 miles on it and was running well when removed (have video). It turns freely and there is no appreciable axial play. Run on Mobil 1 Synthetic oil, never put on the track or raced. Bolts on and gives 330 hp according to Stillen. It has been stored for the last few years. The only issue is that the oil cooler has a small rock dent and it weeps a bit of oil. I have a replacement cooler, but it is a different size.
A&P Racing Brakes- 4 piston calipers with 330mm rotors- need 17" wheels min. Calipers and 2pc rotors need a complete rebuild. I have the parts for the calipers. The rotors should be replaced as well, and a new hardware kit installed.
Autometer Shift Light with 6k pill
Supercharger Kit Parts:
1- VORTECH SUPERCHARGER & MOUNTING PLATE ASSY.
1- AIR FILTER ASSY.
1- CRANKCASE BREATHER ASSY.
1- OIL FEED LINE / SUPERCHARGER
1- FUEL PUMP & MANAGEMENT ASSY.
1- AUXILIARY FUEL PUMP ELECTRICAL ASSY.
1-POWER STEERING COOLER
1- COOLANT OVERFLOW RELOCATION
1- WINDSHIELD WASHER BOTTLE
1- BYPASS VALVE
1ea. BOSCH bypass valve
1- OIL DRAIN BACK
1- FUSE BOX RELOCATION
1- PRESSURE PIPE ASSY.
1- INLET PIPE
1- BELT ADJUSTER / PULLEY
1- IDLER PULLEY
1- VACUUM FITTINGS
Brake Kit Parts:
2- CALIPERS, 2 MOUNTING BRACKETS, CALIPER SEALS, 2 ROTOR HATS, 2 OLD DISKS
1- AIR FILTER ASSY.
1- BYPASS VALVE
1- OIL DRAIN BACK
1- INLET PIPE
1- IDLER PULLEY
1- VACUUM FITTINGS
Brake Kit Parts:
Mar 12, 2020 12:06 AM
