WA 00-01 OEM 5th Gen FX-R Headlight Retrofit
Old Oct 30, 2014 | 09:04 PM
Genes1s's Avatar
A pair of OEM 5th gen headlights retrofitted with FX-R 2.5" BiX with Phillips 85122 bulbs. It has pretty rare late model Infiniti M45 projector shrouds that have green tint which gives cool effect. Headlight lenses were also restored. The OEM turn signal bulbs and sockets are not included in the sale. I have this on my car for at least for 1 week and it has been working flawlessly.
$270 + Shipping.
Headlights were tested for leak prior installation and it is water tight. but light/mist fogging still happens when it weather is really wet and humid due to moist air that can't escape the headlight quick enough.
Light fogging on the corner by radiator. It will go away in about 30 minutes or so
Can't really tell from the frontal view though...
Built thread.
https://maxima.org/forums/5th-genera...ml#post8989832
Old Oct 30, 2014 | 09:08 PM
Genes1s's Avatar
I have 2 people interested in this, I'll PM them if they are still interested.
Old Nov 1, 2014 | 12:46 AM
Genes1s's Avatar
No respond from them. Item is back on sale.
PM with offer.
Old Nov 2, 2014 | 08:38 AM
Genes1s's Avatar
Pending sale
Old Nov 4, 2014 | 07:17 PM
David3267's Avatar
Do you have a retro in the fogs??? For sale maybe?
Old Nov 4, 2014 | 07:43 PM
Genes1s's Avatar
Sure, you will need to modify the bumper opening a to clear the housing though.
If interested PM
Old Nov 4, 2014 | 08:03 PM
Genes1s's Avatar
Added AMP-D2S connector and rubber back seal to make it look cleaner and seal better.
On the car...
Old Nov 4, 2014 | 09:43 PM
Bklyndeem's Avatar
dope
Do u retrofit 2001-2003 i30's?
Old Nov 4, 2014 | 10:33 PM
Genes1s's Avatar
Never done one before, but this could be the first
Old Nov 11, 2014 | 01:20 PM
Genes1s's Avatar
Added few more pics.
Bump, still pending.
Old Nov 13, 2014 | 09:08 PM
Genes1s's Avatar
Sold.
New rubber back cap. Make sure the turn signal bulb socket is installed correctly. This turn signal area is prone to let the moisture in.
W/50W Mori Ballast.
w/50W Ebay ballast (top), 50W (bottom)
You can see that ballast quality makes a big different in the beam intensity. I suspect they it will be the same case with 35W Mori and 35W aftermarket.
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
