Hayden Tranny Cooler Install Question
Old Jul 18, 2002 | 09:51 PM
KeVinMaxFan's Avatar
I have had my 01 Max for a few months now and want to install a tranny cooler. I have just purchased the Hayden 677 transmission cooler (stacked plate version) after much research on Mid-Duty Tranny Coolers. I have had a couple trannys fail on me in other cars and I want to do as much as possible to keep this one going as long as possible. I installed the fin type on an old Minivan of mine with great ease and have seen plenty of posts on those types.
Anyways, I am trying to see if anyone has any experience with the stacked plate tranny cooler install.
I plan on following Greg Pretes Mod post about installing on a 4th gen. I have my digital camera ready so I am hoping I can put something like that to help out all my 5th Gen posse.
2nd Question: Does anyone know if installing an aftermarket cooler will void the factory warranty?
Thanks for the help! Just joined the forum, glad to be aboard.
Old Jul 19, 2002 | 05:30 AM
mdeal's Avatar
I used the same instructions that you have indicated. You should be fine in that regard although I would recommend checking the how-to section for a 5th gen application before you go through your own documentation process. Don't know about a stacked type: I went with the basic Hayden unit.
Old Jul 19, 2002 | 06:15 AM
Tanman's Avatar
I installed the stack type B&M Supercooler in my 5th gen. Followed Greg Prete's instructions, they work fine. Just follow the directions, and be prepared to get a little cut up, some sharp edges there. Get extra hose, you'll need about 8 feet total. Also when you connect the return line to the tranny, the hose might bend sharply a little, thus slowing the flow of fluid from the cooler back to the tranny, which is a bad thing. Give the hose enough slack (use wire ties to bind it to the underbody in a manner where there's plenty of free hose going to the tranny).
I've seen some guys install the cooler with the hoses attached at the bottom of the cooler, and I think this is a bad idea. The fluid should go down into the cooler, then back to the tranny, not be forced up into the cooler, then drain out of the tranny.
Lakersallday24
Jun 16, 2019 01:35 AM
Rage Maximus
Sep 3, 2015 12:26 PM
seesole
Aug 26, 2015 11:22 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
Supragte
Aug 12, 2015 10:00 PM
