removing shift surround
Old Jul 23, 2002 | 01:33 PM
MaximaZero's Avatar
Needs non-Maxima Friends
im taking apart my dash but am having trouble disconnecting the cigarette lighter wire from the piece that surrounds the shifter. how the heck do you do it?
Old Jul 23, 2002 | 01:36 PM
Igor911's Avatar
Re: removing shift surround
Just pull the black harness part really hard! Thats what works for me
Old Jul 23, 2002 | 01:41 PM
MichaelAE's Avatar
Re: Re: removing shift surround
Yeah, pull on the sucker...there is no clip...just pull.
Old Jul 23, 2002 | 01:48 PM
MaximaZero's Avatar
sweet!
now how the hell do i get teh damn cigarette lighter piece out of the trim piece?
Old Jul 23, 2002 | 01:49 PM
Igor911's Avatar
Re: Re: Re: removing shift surround
sweet!
y do u want to do that?
Old Jul 23, 2002 | 01:50 PM
MaximaZero's Avatar
Re: Re: Re: Re: removing shift surround
im feeling artistic today.
Old Jul 23, 2002 | 01:52 PM
Igor911's Avatar
Re: Re: Re: Re: Re: removing shift surround
Im not sure how to do that. I think u might want to remove the outer circle on the trim and then maybe pull it out? I have no idea?
Old Jul 23, 2002 | 01:53 PM
MichaelAE's Avatar
sweet!
That's a bit trickier. There is a little piece of plastic on either side of the adaptor which juts down into the holes in the metal to keep the pieces attached. You have to lift both of those plastic pieces up to get the sucker out. I did this with a flathead...did one of them and pulled just enough to prevent it from re-seating itself and then used the flathead on the other side. It can be a little tough, but you'll pull it off with a little patience.
Old Jul 23, 2002 | 01:56 PM
Igor911's Avatar
Mike,
Now i have a ? for you. My cig. lighter is a little loose, like if i plug something into it, you can move the plug left to right. Is their a way to tighten this so it will not move?
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Click Here: How To
Old Jul 23, 2002 | 02:00 PM
MichaelAE's Avatar
Mike,
That's odd, but I would say get a little eletrical tape and wrap it around the metal piece before sliding it back in. Keep in mind that you should not wrap it with anything flammable since it gets hot in there when in use.
Old Jul 23, 2002 | 02:01 PM
MichaelAE's Avatar
Originally posted by IceY2K1
Click Here: How To
Right...Ice's instructions work well, except I managed the removal of the lighter adaptor while only working out one side at a time while his instructions suggest using two flatheads and trying to do both at once. Whichever works for you is all you need to know. Good luck.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
